Results 1 to 10 of 17
Thread: whats best to use?
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default whats best to use?
    Hi all, im after some tips/products for the silver strips under the side windows as mine have fading/discolour around the edges. any ideas please?? Also a chap from vauxhall said to use turtle wax on my whole car and it would bring it up nice but i thought you should avoid turtle wax??
    Jul 2006
    Hmmm...
    Taking detailing advice from anyone who works for a dealer is probably a bad idea! Turtle wax is OK - it's cheap and won't last very long, and is a PITA to apply by all accounts, but it won't do any harm.
    No idea for you silver strips, I'm afraid - it sounds as if water has penetrated the seal and is causing the damage inside. Might be an idea to see if you can get them as separate parts and just replace them?
    HTH
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    I used turtle wax and quite like it but now have discovered tesco wax lol
    Ipswich,.UK
    Heres a few pics of the problem so you can see what i mean.
    Sunny Dartmoor
    Will have to replace them m8,thats the only way..........
    Regular Member david.aka.judas's Avatar
    Suffolk
    i looked at changing my black ones to silver, but each section was about 35 quid......gulp.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    They will polish out mate. AG SRP, Megs NXT or Scratch X will do the trick or even better Megs NXT for off the shelf stuff. Mine were like that when I bought the car, now there sorted.
    Ipswich,.UK
    Fantastic Rushy, i will give them a shot, is it the Meguiars NXT All Metal Polish - Steel , Chrome Polish??? many thanks
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I originally did it with the NXT Wax but the chrome polish should do the trick. Anything with mild abrasives really.
    Regular Member Little John's Avatar
    North West
    There are no abrasives in NXT wax.
    Most important is to get some masking tape (not the cheap stuff or you will end up trying to remove the glue after) and mask the paintwork off before you try polishing the clear coated chrome strips. I wouldn't use the metal polysh myself as it is a little to abrasive I think.
    Before just hitting it with a product you should try to find out what is the problem, the images show it looks like the clear coat has lifted from the chrome, that can't be repaired, if you soak the area then water will get under you should be able to press the areas and see the water moving around if this is the case.
    If polishing will fix it then water wont get under and the marks are on the surface so have a go with something like megs deep crystal step 1 paint cleaner then if that doesn't work try scratch X. don't forget to mask the black plastic and rubber bits or you will get product in the grain and it can be a ****** to shift.
  1. Whats in the box
    By bigmac in forum Insignia car chat
    Last Post: 21st September 2011, 18:08
  2. Whats in the box?
    By Ginge7289 in forum Styling
    Last Post: 19th September 2011, 22:00
  3. whats this then....
    By bunsen1 in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2010, 23:28
  4. Another whats in the box..
    By blue estate in forum The 'Off Topic' room
    Last Post: 10th May 2009, 21:54
  5. Whats The Name
    By lilangel in forum General Chat
    Last Post: 8th April 2008, 20:21
