Results 1 to 10 of 11
Thread: Nokia 6300 Gallery Access Problem-HELP
    Birmingham
    Default Nokia 6300 Gallery Access Problem-HELP
    Hi,
    My brother has a Nokia 6300 and since yesterday he is getting problem when accessing his Gallery and general use of the phone.
    When going into gallery and sometimes generally using it either hangs or simply crashes then goes back as if you have just switched it on.
    Sometimes it just keeps the processing bar on full and then crashes.
    Have also had this message:
    - message memory not ready;
    Anyone comes across this problem or similar? Help would be appreciated. Any quick fixes?
    Thanks in adv!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Dal150's Avatar
    Apr 2008
    Leeds
    Default Nokia
    Ey up mate,
    Lookin at your symptons, it's defo a software issue.
    The nokia website will have a software update available, just be aware if an update is done the phone will go back to how it was when bought with nothing on it, take the memory card out first.
    Good luck
    Dal
    Feb 2006
    Dorset
    try pulling the battery with the phone switched on , leave it out for a min or so and put it back in and switch it on , also nokia have a software upater you can download and update your phone .
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by Dal150 View Post
    Ey up mate,
    Good luck
    Dal
    It will only go back to standard if you don't do a back up first
    Quote Originally Posted by DennisTheMenace View Post
    I've upgraded the software on my N73 the other day, make sure you back up all files using Nokia PC suite first.
    Also, as per instructions during software download, don't use the phone or disconnect any cables. If you do, it can crash the phone & you will have to send it away to be sorted.
    Once the software was upgraded, all I had to do was copy the backed up details back using PC suite. Didn't lose any contacts or settings
    Birmingham
    Ey up mate,
    Good luck
    Dal
    Cheers folks, anyone got a link for the right download?
    Can I do it at hiome myself? I have the cable for it!
    Bye bye Vec B
    - Hello Siggy!
    Jan 2006
    Skynet HQ EMEC#5
    Go on here:
    http://www.nokia.co.uk/A4222213#
    Or on here, type in phone's product code & it will tell you the latest software version available.
    http://www.nokia.co.uk/link?cid=EDITORIAL_799358
    HTH
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Its not an issue with the microSD card?
    Birmingham
    Quote Originally Posted by JuzzyD View Post
    Good point!
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Managed to download the updater and run the application, but whenever it gets to 15%, it stops and says connection to phone lost, RETRY, keeps doing this and will not allow the update to go on.
    Why is it doing this and what can I do get the update on there?
    Bye bye Vec B
    - Hello Siggy!
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Loads of threads around on the problems with updating the 6300. I finally got mine to update the other day, but it took a lot of attempts.
    Mine sometimes hangs when accessing the SD card, but eventually gets there. I'd try another card if you can get one.
    My update finally worked after downloading a new version of the Noia Software updater, so make sure yours is the latest.
    Phil
  1. Nokia 6300
    By spennny in forum General Chat
    Last Post: 10th April 2009, 12:25
  2. Nokia 6300 Bluetooth Car Kit Advice
    By aaruck in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2008, 00:08
