Results 1 to 10 of 18
Thread: Offside Headlamp bulb replacement : SRI bumper, 3.0 V6 CDTI, pre-facelift
    Default Offside Headlamp bulb replacement : SRI bumper, 3.0 V6 CDTI, pre-facelift
    I've replaced three nearside headlamp bulbs, always looked briefly at the offside and hoped I'd never have to replace one!
    Sadly the Low Beam warning came up whilst parked last night, kind of knew and Yes, it's the offside headlamp bulb that needed changing
    My first attempt was with a pair of long nose pliers, but there just wasn't enough clearance
    As a result, I took the car out of service
    On return I then read Facelift Front Light Bulb Replacement
    Sadly, that's for the facelift
    So read Front bumper removal / fitting Irmscher Spoiler
    In the daylight today I removed the two Torx screws, unclipped the bumper, removed the offside top bumper clip, but found there was still not enough clearance to access the 8mm bolt under the headlamp
    I then had to undo the other two 8mm bolts under the bumper, this then allows the bumper to drop about 15mm and gives the required clearance to access the final headlamp fixing bolt
    Before refittting I modified the headlamp bulb clip, so that it can be removed more easily should the bulb fail again
    I then bolted it back into place and tested, and a vast improvement
    Sadly if the full beam bulb fails, then there is no choice the offside of the front bumper has to come off again!
    Total time about 20 minutes
    Full Member Big Sig's Avatar
    Its a right pain, managed to replace my sidelight without removing anything, apart from a bit of skin!
    Access to the sidelight is limited, but possible
    I had already tested that!
    Access can be improved by undoing the MAF sensor housing and pulling it out of the way
    Sadly the instructions in the handbook for replacing the headlight bulbs are a complete waste of time
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you can also remove the airbox m8
    Here, there and every where!
    Remove the airbox. Easier and quicker
    [Ex]Admin Duncan's Avatar
    Absolutely no need to remove the bumper to do it, not on a pre-face. Facelift is a different matter for certain bulbs.
    There isn't enough room to get access to the headlight and definitely not enough room to get to the high beam light
    I did look at removing the air box, but it also looks like one of the bolts is underneath, bad enough with the electrics box sitting on top of it!
    Either way, there should be NO need to go to this degree of dismantling
    You, and by that I mean any person, should be able to change any bulb (excluding the foglight bulbs) without the need for any tools
    The bit underneath the airbox isn't a bolt, pretty sure its a rubber mounting. However I so agree its a very poor design!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I mangaged to change all the bulbs, headlight & sidelight, without dismantling anything, but what I expected to be a 5 minute job took well over an hour. Changing the bulbs themselves wasn't too bad but with my hand squashed in the tiny space I couldn't get enough leverage to twist the bulb holder into place. When I did the HID conversion I opted to take the airbox out.
    [quote=m8internet;640056]There isn't enough room to get access to the headlight and definitely not enough room to get to the high beam light
    I did look at removing the air box, but it also looks like one of the bolts is underneath, bad enough with the electrics box sitting on top of it!]
    Yep, it's a rubber mounting on the bottom, airbox simply pulls off from it.
    Quote Originally Posted by Ian S100 View Post
    Yep, it is possible to do it without removing anything/needing any tools - I've done it with mine. Fiddly for sure, but possible.
    You think the Vectra is bad?, especially the facelift - you wanna see some other makes/models for changing bulbs. It's half the flippin' front end off!
  1. Facelift front fog bulb replacement
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2011, 10:41
  2. Vectra C Headlamp bulb replacement
    By mss in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 12:41
  3. Facelift Bulb replacement
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2009, 08:54
  4. recommended headlamp bulb replacement
    By andy.l in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2009, 00:05
  5. facelift bulb replacement
    By mat osborn in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2009, 19:51
vectra c headlight bulb change
vauxhall vectra headlight bulb change
how to change a headlight bulb on a vauxhall vectra
vauxhall vectra c off side headlamp bulb replacement
vauxhall vectra headlight bulb replacement
how to replace a headlight bulb on a vauxhall vectra c vectra c replace headlight lamp2007 vauxhall vectra sri low beam bulb replacement2007 vauxhall vectra sri low beam bulbchanging vectra c headlight bulbvectra c bulb changereplacing vectra c headlight bulbchange headlight bulb vectra c v6replacing h7 bulb on 2007 vectra 1.8 srichange headlight bulb on vectra cvectra headlight bulb replacementvectra c nearside headlight fittingoffside headlight vectra cchanging bulb on vectrachanging vectra light bulbs 2007vectra dipped beam bulb replacementhow do you change a lightbulb in the headlamp of a Vauxhall SignumHow to change headlamp bulbs on a 2006 Vauxhall Vectra 3.0 CDTIhow to change headlight bulb on vectra 2008 offside
