Thread: front calipers? back calipers?
    Regular Member kenny1zero's Avatar
    Apr 2008
    corby
    Default front calipers? back calipers?
    Hi all hope all are ok, was wondering if anybody out there knows if i can take the front calipers of the front and put them on the back after they bn painted,will they fit the rear,iv just bought the big break conversion from lmf,they are getting painted for me,but want the others painted too,but dont want to leave car with out breaks while they get painted,
    i will be photo the cahnge over and doing the lowering kit at same time!!!! god help me!!!!
    Jul 2006
    Mexico
    Not an expert on that matter mate but I think you cant flip the fronst to the back.
    Some one on here will give you more detailed info on the matter
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    No, totally different...
    Apr 2008
    corby
    Default breaks
    ok thank you both for that,i'll nave to take them off and get them painted.couple days with out my car not that big a deal !!!!!!!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the front calipers have just the piston to apply the pads to the discs, and on the rear is the same sort of design but are alot smaller and also have the hand brake mechanism built in hth you m8
    Jul 2006
    And if it helps, there's no need to remove the calipers to paint them - just remove the wheel and get the car up on axle stands, should give you plenty of access.
    HTH
  1. vxr calipers/ 314mm calipers needed
    By rozzer2006 in forum Handling & Braking
    Last Post: 17th September 2012, 11:28
  2. Rear brake calipers wind back tool - Herts
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 21:24
  3. Calipers back from recon, & other new bits !!! Pics !!!
    By thefibreguy in forum Handling & Braking
    Last Post: 18th July 2010, 19:24
  4. are 3.2 v6 front calipers the same as 1.9 cdti front calipers
    By gazturbo in forum Handling & Braking
    Last Post: 5th May 2010, 19:11
  5. Replies: 1
    Last Post: 21st October 2008, 15:11
