Results 1 to 10 of 13
Thread: Brake Pad Sensor Replacement
    Regular Member andy13's Avatar
    confused Brake Pad Sensor Replacement
    Just bought a new brake pad sensor (part no.24427919) and just taken the front wheel off to check they look the same but they look completely different. The plug on the car is blue and quite small whereas the new one is black and looks nearly double the size. Also the length of the new cable looks far too long.
    Any ideas?
    Jul 2006
    Mexico
    Just check if the plug have the same pins and check if it fits if so just fit it
    Regular Member poves's Avatar
    lancashire
    Is that not the connector for the other end , rather than the terminals in the pic ?
    btw u can do a kwik fix by snipping the wires and crossing them together , this will knock the light out.
    Jul 2006
    Mexico
    Now that you mention it.....the second pic looks right....same as the plug for the sensor I just bought 2 weeks ago...what looks strange is the first pic...
    lancashire
    Default Stop !!!
    I THINK THAT'S THE ABS CONNECTORS !!!!!!!!!!! SOMEONE ?
    The connector pushes onto the pad ? yes / no ?
    Jul 2006
    Mexico
    Agreed....I think that first pic does not show the brake pad sensor plug....Andy follow the original line from the sensor to the plug and follow the trail...the existent plug has to look the same as the new one that you bought.
    the blue plug comes from the rear of the brake pad and the grey one comes from somewhere near the front of the pad (cant really see exactly). The rear of the brake pad being the front edge of the disc.
    lancashire
    The fitting should be a push fit nipple which clips onto the brake pad near the caliper i think.
    The black plug on your new sensor is'nt the end that goes on the pad , it should have a fitting on the other end.
    Jul 2006
    Mexico
    Andy...I assume your wheel is off....take the old sensor out of the brake pad / caliper and follow the cord towards the end....it will lead you straight to the correct plug.
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    I had to have a new one last week , part no is 13116560 for mine, 1.9 cdti 54
  1. Cam Sensor replacement
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2012, 18:14
  2. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  3. Egr sensor replacement
    By billy_wiz in forum Y & Z30DT Specific
    Last Post: 29th January 2012, 12:16
  4. Rain sensor gel replacement
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2011, 18:45
  5. How much for brake pad replacement?
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2009, 19:53
