hi all ive noticed that nothing is coming out of my rear window wash. when i try i can here the motor as if its coming out nut nothing appears. any ideas whats wrong with it? tia
Maybe a split pipe or pipe has come off,worth a check........
have i got to undo the roof lining?
i dont think its in the roof lining m8 that the problem.
if it was it would be wet.
try a needle in the nozzle incase something is blocking it or check the pipe from the washer bottle to as far as you can.
if that fails then it will be headlining down to see if its kinked (big job)
oh no i hope its not that but then again i want to replace my tatty aerial so it could just do me a favour if it was that!!! will i have to take the bumper off to check by the washer bottle?
bump
if the hose have come off (at the front) then just activate the rear wiper (withe the fluid (dont know english term)) then there will become wet around the front wheels.. easy to spot (if its not raining)
