Thread: How to remove steering wheel controls
    India
    Default How to remove steering wheel controls
    for a 4 spoke (2003 model)?
    The mechanic tells me that the switches on the steering wheel are defective. Can they be removed without removing the airbag? There seems to be a screw behind the steering wheel right under the controls on either side, but wanted to check before I try...
    B
    cambs
    hi m8
    you will need to remove the airbag
    1-dissconect battery
    2-leave for 20-30mins
    3-get a flat screw driver
    4-turn wheel so the hole is at the bottom
    5-place srewdriver in and gentle pull towards you utill airbag clips release
    6-turn wheel round again and do the other side.
    7-pull airbag off and disconnect.
    8-remove airbag holding plate
    9-now remove torx screws at the back of wheel the hold the controls in place
    10-very gentle pull the control from the wheel as these are held in tightly with lugs
    that its m8 all done and it is easy trust me 5mins
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by bnam View Post
    B
    When they say they are deffective, how?, are they not working at all?
    Have you changed the head unit & not fitted a control adapter?
    That would stop them functioning
    Regular Member Matt's Avatar
    in a 3 bedroom house
    i have some switches for sale mate.... pm me if ur intersested
    no i dont i have facelift ones sorry....
    i.e full canbus
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Took mine off without removing the airbag, just undo the screws
    Jul 2006
    Was that a full or half canbus wheel m8? I'm hoping I won't need to take the airbag out to just change the switches...
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by parapaul View Post
    Done both
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by mhvcbv View Post
    hi m8
    Quote Originally Posted by merikiito View Post
    Yep, definitely no need to remove the airbag. All you need to do is undo the screw on the back of the steering wheel that holds them in, then prise them out of the steering wheel.
    It will be a half-CanBus Paul being an 03 - it'll have the three buttons either side. But it's the same principle for the scroll wheel controls too.
    India
    That's great! Will try it this coming weekend.
    B
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. how to remove the CD Player controls from steering wheel
    By akeem in forum Bodywork & Interior
    Last Post: 6th November 2012, 19:32
  3. Steering Wheel controls
    Last Post: 10th April 2012, 10:45
  4. Steering wheel controls..button V roller wheel
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 18:18
vectra c steering wheel controls removal
how to remove steering wheel controls on vectra c
vectrab steerig wheel switchhow to remove steering wheel control vectra chow to remove signum steering wheel controlsremoving steering wheel controls corsa dremoving vectra c steering wheel controlsreering wheel buttons removal vectra csteering wheel Vectra Chow to remove steering wheel butttons on vectra cvxr vectra steering wheel removalinsignia steering wheel removalcan you fit a drift steering wheel to a vectra c vectra c steering wheel sound controls removingvsuxhall vectra C removal of steering wheel switches removal of steering wheel switches vectra cHow to remove trip control steering wheel vauxhall zafira 2011vectra c steering wheel removal
