Results 1 to 3 of 3
Thread: Query - Diesel Filter / Electrics / Transmission Light
    Jun 2007
    Default Query - Diesel Filter / Electrics / Transmission Light
    Had the car serviced Tuesday at a Nationwide Autocentre. When picked up I had strong smell of diesel coming into cab through vent when heater was on. Took back and they said they found a problem with the connetion to the diesel filter which meant diesel has leaked onto starter motor. This is now fixed. However, now when I put key in ignition the 'car and spanner' light illuminates and stays on until I start the engine at which point it turns off. I went back in and told the manager but he said this was usual and there is only a problem if the light comes on when the engine is running. However, I'm pretty sure that it didn't use to come on before the service. Any suggestions would be welcome?
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    Means it had detected a fault and is no longer present.. Dunno if its related to your previous problem though.. Should clear itself from the ECU memory after about 25 clean engine restarts
    Jun 2007
    Many thanks. He said it could be that they had to disconnect a part to rectify the problem and clean the excess diesel from around the starter motor. Could this have caused the fault it picked up and so now is rectified as it was replaced?
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. Location of Automatic Transmission Filter
    By der_stig in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2012, 17:55
  3. Engine Fault Light - Water in Diesel Fuel Filter?
    By rharris21 in forum Engine & Drivetrain
    Last Post: 14th February 2012, 10:06
  4. water in diesel filter, spanner light and fault code
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2011, 19:24
  5. Diesel Particulate Filter Query / Clarification
    By dave45040 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2007, 21:16
