Can I replace the mono screen I've got in my 2005 signum for a colour one and if I do will it display a map using the ndcd 2013 head unit or is that only possible with the CD70?
Probably not the full answer you are after mate but I have the ncdc2013 with colour screen and it does show maps.
You can but its a fiddly job. Basically you need to add 3 RGB wires from the main radio loom to the display loom, on the colour screen there is a separate 12 pin connector (XC20) which has the Combined sync signals, OV and RGB. You need to wire these using screened cables to the navi connector pins 17 (Red), 18 (Colour sync), 24 (Green), 30 (blue), 31 (ground for video). Then you need to get vauxhall to program the colour screen into your car using the Tech2 and match it to the 2003 unit.
Simon
NoW Thats Wot I Call An Answer!!!
I should point out that you cannot use 'any' colour screen, it has to be the proper vauxhall one. (CID) Occasionally they appear on ebay.
Simon
