Thread: squealing brakes
    Coventry
    Default squealing brakes
    I'm noticing a squeal from the near side front brakes when pressing the brake pedal lightly. only thing is, if i push the brake pedal down hard, it still squeaks for a couple of seconds when the pedal is released. it's like the pads are binding to the disc? can this be adjusted? no idea what i need to do and it's really annoying.
    Leigh
    Jul 2006
    Mexico
    A copper grease magic will do the trick mate
    Coventry
    whoops i guess this should have gone in the troubleshooting section!
    What's copper grease magic? is that a brand name and where will i find it? putting grease on my brakes doesn't seem such a good idea!!!
    Jul 2006
    Mexico
    Quote Originally Posted by HooDLuM_X View Post
    This will help mate
    http://forum.vectra-c.com/showthread...=copper+grease
    cambs
    you put the copper grease on the pad runners
    not on the disc
    cambs
    halford sell it
    and it for high heat and does not melt and run off.
    Coventry
    Quote Originally Posted by mhvcbv View Post
    not on the disc
    i knew that
    Sunny Dartmoor
    Don't forget to clean up the caliper and carrier aswell,it'll make the pad slide alot easier and stop some of the squeal too,good luck m8......
    Coventry
    cheers will give it a go
  1. Squealing Brakes
    By richardg3.2 in forum Suspension, Wheels & Brakes
    Last Post: 6th February 2012, 16:17
  2. squealing brakes
    By dcm23251981 in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2012, 01:25
  3. Brakes squealing
    By davidlewis24 in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2011, 20:33
  4. Squealing brakes
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2009, 21:27
  5. Squealing brakes
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2008, 19:19
