Thread: Vertical Load retaining net
    Default Vertical Load retaining net
    Anybody know what kind of job it is to fit the roof 'socket' for this?
    Have picked one up with a few bits, and my 07 Estate doesn't have the catches
    I knoiw it's about £100 for the stealers to do it, but was wondering if you can get the bits and what kind of job it is.
    Hertfordshire
    The fitting kit is about £35 on its own m8, so if stealers fit it for £100, that’s not too bad.
    I have only fitted the fittings above the rear seat, there are others in the box I haven't used.
    It's not too difficult, just fiddly, and scary when you are cutting the head lining !!!
    Thanks For that Green Growler
    I was okay until you said cutting headliner
    I knew it would need it, but not sure I want the net that much
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    ive asked the dealers here to fit it.. they said NO we wont do it.. if you want it you have to fit it your self
    Green growler -> is there markings on the headliner where to cut or?
    Hertfordshire
    Yes m8, there is indeed markings on the headlining, it's kind of recessed where you need to cut out.
    I done mine with the headlining still in the car, just dropped down where I needed to, but this probably just made it fiddlier.
    It’s a fair bit or work to get the whole headlining out, particularly on the estate !
    Engine : 2.2 Direct
    ahhh then ill think i order the 2 bits neede (dont get the hole set.. as just the 2 above the rear seat is 50£ + vat here...)..
    i have had the headlining down... when i put in new roofloom and rearreading light.. dont want to do that again
    when i get it done i dont need my roofcarrier and roofbar as it all can be in the car then....
    H11LGX -> do you know the price for the net? (its the one in the "rollo") as that is 170£ or i can chose the "dog guard" wicht is 150£ both + vat (vat is 25% here
    I bought the net 2nd hand, but I believe on a new car it is £150, not sure what it is to buy as an aftermarket part.
    Scotland
    confused Vertical load retaining net
    Hi, I am just about to change my Omega Estate for either a Vectra estate or a Signum.
    My Omega has a vertical net and this is an accessory I really want to buy for my new car. The net can be attached just behind the rear seats or just behind the front seats when the rears are folded. Although the net and attachments can be bought for a vectra estate does anyone know if it can be fitted to either a Signum or (for that matter) a vectra hatchback?
    Any advice welcomed...
    Regards.
  1. Insignia Insignia Tourer - vertical load restraining net
    By DaveG in forum Insignia Chat (READ ONLY)
    Last Post: 2nd June 2012, 13:06
  2. H7 retaining clips
    By mrroo in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2010, 20:00
  3. Vertical Load Retaining Net
    By H11LGX in forum Parts for sale
    Last Post: 17th October 2008, 08:04
  4. ESTATE - Rear vertical load net
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2007, 13:59
