Thread: You Need To Read This, Rear Brakes
    edinburgh
    Default You Need To Read This, Rear Brakes
    Just been to Vauxhall with un-even rear pad wear and pad closes to the piston nearly down to metal and car has only 8000 miles on it.
    Expecting to fight to get the pads changed under warrenty, the tech guy walked towards me and advises that he will be changing the pads discs and calipers under warrenty, I just about shat myself.
    He told me (off the record) that he is changing at least 2 vectra c's rear brakes a week, vauxhall have had 1000s of failures on the calipers and rear brakes.
    I sujest all members wih low miles get the back wheels of and have a good look at the pads, cause if they are wearing really fast or un-even they will be covered by warrenty.
    The tech guy said that he brake pedal should also be applied first, then the handbrake. SO IF VAUXHALL ASKS, THIS IS HOW YOU APPLY THE HANDBRAKE.
    If anyone needs more info drop me a telephone number and I will be happy to discuss further.
    DONT PAY TO HAVE THEM REPLACED< HEY ARE COVERED UNDER WARRENTY.
    Hope this helps
    Regular Member colalowe's Avatar
    in the North
    Thats worth knowing, ill be checking mine tomorrow
    What year/model is your vectra, does it affect all models or just your type??
    Regular Member Karl's Avatar
    Sunderland
    heh, mine were knackered by about 16k, luckily its a lease car so they just paid for the pads to be changed, wonder how long it'll take for this set to wear down.
    edinburgh
    Default brakes
    Its a 2007 1.8 sri.
    They didnt even bat an eyelid at the fact it is a taxi.
    Seen threads advising 2 to 3 sets of rears to one set of fronts, thats not right.
    edinburgh
    Default brakes
    Sorry, Vauxhall tech guy said its vectra c's in general, not just my model.
    Regular Member GrizzaVision's Avatar
    Preston
    Question Gary
    Hi all, this is my first post so please be gentle with me. I have a 04 2.0 dti 32k. I have just noticed a grinding noise (every now and again) from the rear n/s when under breaking, same problem? Thanks
    Full Member Big Sig's Avatar
    Best bet is to whip the wheels off and have a quick look
    edinburgh
    Default brakes
    As above mate get the wheel off.
    Sounds like the pads are goosed, discs will be now as well.
    Sounds a bit anal but get the wheels of every six months or so (more if you do a high milage) and check pad wear.
    You could have saved cash on discs if you spotted it sooner.
  1. rear brakes
    By HARRY SRI in forum Handling & Braking
    Last Post: 2nd April 2011, 22:56
  2. rear brakes
    By scottymartinXPSRI in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2009, 09:51
  3. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
