Thread: Lowering Help!!
    norfolk
    Default Lowering Help!!
    Hi All, I Have A 1.8 Ls 2002 I Am Looking To Lower The Car, Can Anyone Tell Me Can I Just Put Sxi/sri Springs Straight On? Or What Is The Best Option Without Spending A Fortune, ... Oh! I Also Have 17" Rims Which I Am Going To Put 215/50/17 Tyre's On Cheers..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes u can put Sxi/Sri springs on as long as they come from a 1.8 due to the springs being tailored to the weight of the car. I think all rear sxi/sri springs are the same on all models, its only the fronts that differ. Would suggest that u get some Eibachs as the VX ones are prone to breaking.
    I had PI ones on my 1.8sxi Vectra C saloon and they were ok
    http://www.europerformance.co.uk/pag...product=551620
    If you want to go more than 30mm then u really should replace the dampers for shorter ones. TBH I would and did with the 30mm drop.
    Eibach are the best ones which I have fitted to my 1.9cdti Vectra C Hatch, they look and feel much stronger but then they cost more than the PI ones.
    Also u will need to get you wheels realigned (4 wheel alignment) but you want to leave that for a couple of weeks so they settle first.
    norfolk
    thanks for that mate, how hard are the springs to change? what special tools are needed, if any.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Think there might be a how 2 somewhere on the forum
  1. Lowering on the sri.
    By Roy_Vec in forum Tuning
    Last Post: 13th September 2009, 09:15
  2. Lowering again
    By Ziggy in forum Handling & Braking
    Last Post: 2nd June 2009, 14:19
  3. Lowering
    By euro-dee in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 01:22
  4. Lowering
    By s1nglef1sh in forum Handling & Braking
    Last Post: 6th November 2008, 22:46
  5. lowering???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 23:49
