Thread: Tweeter replacement in vectra c, 2004.g.
    Croatia
    Default Tweeter replacement in vectra c, 2004.g.
    I need to replace original tweeters but i dont know how to remove them. Do i need to take the whole door panel off or just tweeter housing?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    You can get the tweeter housing out without removing the door panel easily enough, but getting it back in is a bit more fiddly because of lining up the clips.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Too late to edit the above post, but a couple of pics from my ICE thread that may help illustrate it for you.
    Croatia
    Thanks, i ll try to pull them out. Is there a chance to brake something? Some clips or other plastic bits?
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    There's three white panel clips that should just pull out (you can see one of them in the top photo above in the top clip position. The other two positions also visible in that photo are empty in that pic.they pull straight out easily enough, but getting them back in whilst holding the tweeter housing at an angle to get it behind the door panel is a bit fiddly
    Regular Member VECTRA_C_VIPSTYLE's Avatar
    CHESTER
    did mine found it east'r to take the door pannel off took the tweeter out and fitted polk audio 1's to the out side of the grill look wicked
  1. Replacement radio for 2004 Signum - Suggestions
    By rowladar in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2011, 15:06
  2. Tweeter not working on C SRI
    By Chris Nock in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2010, 21:34
  3. 2004 1.8 gearbox oil replacement
    By rubachuk in forum Engine & Drivetrain
    Last Post: 25th January 2010, 15:51
  4. Tweeter Loom??
    By seanyis in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2008, 10:45
vectra c tweeters
vectra c tweetery
https:www.vectra-c.comforumshowthread.php53290-Tweeter-replacement-in-vectra-c-2004-g
opel vectra c door panel removal
opel signum door panel
clip opel vectra c
vectra c door panel remove
opel vectra c tweeter adapter
