Results 1 to 10 of 11
Thread: Flexi Brake pipes
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Default Flexi Brake pipes
    Since the 314 brake upgrade when i am on full right hand lock i get a squeak from the drivers side wheel on close examination i believe it is the brake applying it self slightly, as the flexi brake pipe seems to be very tight,
    So are the 3.0 flex pipes longer or should i just unclip it from the suspension leg to give it a bit more freedom, or try and convince the bank manager i need some metal flexi`s ???
    Phil.
    Also will have a similar problem when i do the 292`s on the rear with the brake pipes ???
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by phil67 View Post
    Phil.
    if you unclip the flexi hose it might rub on the tyre and put a hole in it
    so try and pull the cable a bit and move the hose as far up as you can on the caliper if that doesn't work then you might need to get longer hoses but if that is the case then get bfgoodrich hoses (metal ones)
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Cheers matey, can you tell Lee i may be contacting him shortly to get my new boot spoiler painted when it arrives.
    no worries m8 but he is away next week
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Cheers for that.
    Cheers for that.
    but he is still open i think i will find out and let you know
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Phil.
    Was wondering how you was getting on with them... As i said i'd got some flexi's fitted on the front on mine and have no issues with them. Got mine from LMF, the front fit fine but their back ones dont... Still to be resolved.. And oh btw, to save a pm, am free from the weekend after next onwards
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    So i take it that both the 1.9 and the 3.0 motors share the same size flexis then?
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Dunno bought that but mines the 1.9 dont forget...
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Quote Originally Posted by plasma View Post
    LMF have withdrawn the Vec C brake lines due the problems as you stated with the rears not fitting, so i rang Goodridge technical team and asked them the story to which they replied that Vauxhall have used two different sizes in the manufacture a 10mm and 12mm fitting, the bloke said the only way to find out which one you have is to remove the pipe from the rear and measure it, but that means bleeding the brakes and waiting 5 to 7 days for delivery as they are not on the shelf.
  1. Brake Pipes
    By st2malo in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 12:46
  2. brake pipes
    By DTi Elite in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2012, 22:00
  3. where to get rear brake flexi hoses
    By peadar in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2011, 21:37
  4. tool to remove flexi brake lines
    By mparks8590 in forum Handling & Braking
    Last Post: 15th December 2010, 22:28
  5. Brake Pipes.
    By djveccy in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2010, 00:42
