Thread: help - strange noise
    Regular Member satbeychap's Avatar
    Devon
    confused help - strange noise
    as per thread title, i have a strange noise whilst driving. sounds a bit like when you have a stone in the tyre - definately related to my speed. pretty sure its coming from offside rear wheel. its a rythmic mettalic tapping; dissapears when i press the brake.
    Ive had a quick look around the rear wheel/caliper but cannot see anything which may be causing it. brakes and handling are not affected.
    Anyone got any ideas?
    thanks
    Devon
    anyone?
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Could be a couple of things, Pads getting low or Binding slightly, The other could be a wheel bearing.
    Really needs a proper visual investigation to be sure !!
    Dean
    Devon
    thanks dean. i'll have to jack it up or get it on a ramp and see what i can see. i hate putting a car into the garage when you dont know whats wrong - just gives the garage an excuse to spend ages finding the problem! £££
    mansfield notts
    i had this problem, it turned out to be the metal profile of the pads slapping against the caliper, had new pads fitted, noise now gone
    Essex
    Definatley sounds like wheel bearing on the way out..
    suggest check others like stone in tyres,,,, or brake parts first. (easiest)
    But most likley is the bearing
    Mike
    Full Member Big Sig's Avatar
    Wouldn't the bearing make a droaning rather than a clicking noice??
    Essex
    It can
    Squeel
    Drone
    Tick.
    Or even Griiiiiiiiiiiiiind (time to change it)
    Mike
    Maida Vale
    Stone in the tyre? Unless it's a really teeny stone, the vibration at 70-80mph would be bad enough to throw the balance weights off the wheel.
  1. strange noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2012, 14:00
  2. Strange Noise
    By fattony in forum Suspension, Wheels & Brakes
    Last Post: 26th June 2011, 14:24
  3. strange noise
    By trev16185 in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2011, 08:27
  4. strange noise
    By chrosty in forum Engine & Drivetrain
    Last Post: 11th December 2010, 03:20
  5. Strange Noise
    By spennny in forum Engine & Drivetrain
    Last Post: 29th June 2008, 19:32
