Results 1 to 10 of 28
Thread: EML after fitting Caterman box
    Regular Member MattW's Avatar
    Sheffield
    Exclamation EML after fitting Caterman box
    I've fitted the caterman tuning box this afternoon, and I did origially fit it upside down, as the RPM went to 1500, so I swapped it round, and now when I start the car, the Engine Management Light comes on, and then goes off. It didn't do this before I fitted the box.
    I've had the box off, and it still does it, so I re-fitted, and had the battery off for 30 mins to try resetting the ECU.......still get EML on startup.
    The box is working, as it pulls a hell of a lot harder. Anyone got any suggestions?
    The eml is probably because you fitted it the wrong way round. Its saying its recorded a fault.
    Sheffield
    Should the reset of the ECU have cleared it though? I've had the battery off for 30 minutes, or shall I leave it off for longer?
    As said, the EML does go off straight away once the car ignition starts.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Just try disconnecting the battery again for 30 mins.
    EDIT. 25 starts without the fault will clear the code I think.
    Here, there and every where!
    It will do that when you fit the box the wrong way around. It can be cleared by the dealers, mine did a few times when testing different boxes. It has stored a fault but is not causing a problem, ask them to clear it if it goes in for a service or if they are decent they will do it F.O.C. for you My dealers did
    Sheffield
    Brilliant, I was a bit worried, and didn't want to "enjoy" the box to it's potential. I'll take it back to the dealers tomorrow and get them to clear it, as I've only had the car 2 days
    If you take it back to them, remove the box first
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Dont forget to take the box off and keep stum LOL
    Sheffield
    Don't worry, I'll remember to take it off
    Sheffield
    I've had the battery off for an hour this morning, and that hasn't cleared the fault either. Going to give Vauxhall a ring this morning, as I've taken the box off, and get them to reset it, as there is a slightly rough idle as well, which was there when I picked the car up, and they said they would Tech2 it if it didn't go away.
  1. CDTi 150 Caterman fitting guide?!
    By RobW in forum Diesel Engine related
    Last Post: 14th October 2007, 11:36
  2. fitting caterman
    By ilaing in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2007, 23:08
fitting eml
