Results 1 to 2 of 2
Thread: Limp Home mode
    Mar 2007
    Kenilworth
    Default Limp Home mode
    My car has done this several times now I donít know whether any body else has noticed and experienced this or even if it is not related, the car has done about 23,000 miles only itís a 3.0ltr diesel Auto 6 speed box and this is what I have noticed.
    When the auto box changes up too early dropping the engine revs below 1500rpm I am most likely to get a problem, it does this when warming up or after being driven at a constant speed for a fair length of time and then driving slow like coming off the motorway into traffic on a side road, the auto selects a gear that drops the revs to just over 1000 and before long it goes into ďlimp homeĒ mode and the spanner light comes on. If I stop switch off for 30sec then restart everything is fine, the spanner light goes out itís as if the engine management system throws a wobbly and has to be reset.
    My faith in the dealers sorting it out is poor but Iím going to log the times and dates of when it happens and see if I can get it sorted before the warranty runs out, last time I was charged nearly £80 for hooking up to the analyser which found nothing stored even though the Mechanic symbol did come on, I think you have to get it read before turning off and resetting, if the light stays on a code is stored if it goes out the reset must wipe the history. My normal way of negating the auto is to select manual and keep the revs above 1500 but it is very frustrating I might as well have bought a manual box, another way is to floor the throttle and give the engine management a different driving pattern it then behaves correctly for a few miles but it gets difficult explaining to the police that my car needs a burn-out or it goes to sleepÖ.!!!
    Does any one else suffer this problem..?
    If its stored a fault the spanner light will light up and go out everytime you start the engine for the first 25 or so restarts. Although mine doesn't. Best bet is when it does it again, take it to the dealer with the light on and leave someone in the car, with the engine running so you can go in and tell them. They should read it there and then. As its got a fault code I can't see how they could then charge you a fee for reading it. Also see if you can replicate the fault so you could take them out and show them how and when it happens.
  1. limp home mode
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 22nd September 2012, 09:12
  2. Limp Home mode
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 19:43
  3. limp home mode
    By fig in forum Engine & Drivetrain
    Last Post: 20th January 2010, 23:18
  4. CR2 going into limp home mode
    By plasma in forum Diesel Engine related
    Last Post: 17th April 2006, 20:45
