Thread: Replacing CD Player
    Darlington
    Default Replacing CD Player
    Hi
    Does anyone know if I replace my standard veccy c CD player with a touch screen monitor will i lose the display on the screen where it shows fuel consumption, mpg etc?
    Sunny Dartmoor
    Think you do,iirc,sure someone will be on later to confirm......
    I don't think you lose the fuel computer bits, but it will mess up the clock and date. I'm not 100% though.
    Regular Member signum junkie's Avatar
    Edinburgh
    Its half can bus if its 53reg so no you wont lose info on screen but may lose steering wheel control.
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Easiest thing to do is pop the existing CD player out and try it.
    On my full Canbus car 2005 without the radio in the display still worked and showed all the normal computer things (MPG, trip distance etc) and you could still use the left hand wheel on the steering wheel to change the display between the settings.
    One thing you can't do is change the time without the original radio.
    Here, there and every where!
    Trip computer will still work but you will lose the ability to set the clock and without the correct adapter leads the steering wheel controls won't work for the headunit Alpine, Sony, Kenwood and Pioneer do adapter leads for the Veccy.
    http://www.caraudiocentre.co.uk/cate...pter_c-985.htm
    http://www.caraudiodirect.co.uk/vehi...2c15d16c08fd59
    http://caraudiosecurity.com/shop/pro...s_id/7094.html
  1. replacing CIM
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2011, 19:57
  2. egr needs replacing?
    By family guy in forum Engine & Drivetrain
    Last Post: 20th April 2011, 10:41
  3. Replacing Tie Rod and Tie rod end
    By chazuwe in forum Vectra C / Signum Troubleshooting
    Last Post: 25th March 2011, 13:46
  4. Replacing DMF
    By RikD in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 21:55
  5. replacing TID
    By darko2301 in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2009, 21:41
