Thread: Oil Service Light Keeps Appearing
    Regular Member Mowster's Avatar
    Cornwall
    Default Oil Service Light Keeps Appearing
    I know how to reset the service lights. Just done an oil change and did a reset . All ok for about a week and then light re-appeared. Done this a couple of times now and get the same problem. Any help would be appreciated.
    Just thinking, it only appears a few seconds when the ignition is turned on and then it goes out. Is this supposed to happen?
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Mowster View Post
    Yep, perfectly normal. Under normal circumstances it comes on when you turn on the ignition and goes off shortly after starting the engine.
    Cornwall
    Cheers Duncan, how would I know a service was due. If I press the trip reset (as per manual) all that shows is the oilcan/spanner. It does not show remaining milage?
    Regular Member D4M0's Avatar
    May 2008
    wigan
    how do u reset the service light,i did mine but used a scanner is there another way without this, i had an astra and could that without a scanner my 05 veccy is just cummin up to 10,000 miles now so gonna do oil,filter,etc but no service will come bk on shortly thanks
    If it doesn't show the remaining mileage when you press the trip reset button with the ignition turned off, then it means you're on the EcoService schedule (fixed schedule of 12 months/20,000 miles - whichever is sooner) as opposed to EcoFlex (Max of 2 years/20,000 which is dictated/affected by your driving style).
    The first indication you'll get is when the oil can/spanner symbol pops which indicates a service is due within 1,000 miles.
    Cornwall
    Quote Originally Posted by D4M0 View Post
    Go to http://forum.vectra-c.com/showthread.php?t=30344
    This will tell you how to reset
    Cornwall
    Cheers m8, thanks for your help.
    May 2008
    wigan
    cheers m8
    Regular Member silverhairedracer's Avatar
    ESSEX
    Quirky this ! just had my light come up as well to day showing 1000 ,miles
    looks like its a service and its 1st MOT at the same time.
  1. Why has this started appearing everywhere?
    By m8internet in forum General Chat
    Last Post: 12th June 2012, 15:40
  2. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  3. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
  4. The Disappearing Re-appearing Man!
    By BigMan in forum General Chat
    Last Post: 6th December 2007, 14:08
how to reset oil service light on vectra c
reset oil service light vectra c
