Thread: Range not changing
    staffordshire
    Default Range not changing
    Hi All,
    Just purchased our first veccy, it is a 2.8t v6 auto elite on a 56 plate.
    Anyone experienced an issue with the range not moving from around the 225 mile marker, it has been stuck there since the tank was full and we are now just inder half and it is still saying 222 - 225?
    Does the range not show above 225 miles?
    Thnx in advance.
    James
    It should do, I think a trip to the dealer is in order to sort that.
    The range is based on how much fuel you have in the car and how you've been driving for the previous 30 or so miles.
    So if, for example, you drove very 'spiritedly' when you first filled up the range would show drop to a figure that was below 'average'. If you then drove more sensibly from that point on you'd be getting better mpg so your range would be improving i.e in this case not dropping at the same rate as it was initially if you see what I mean.
    Jul 2006
    Mexico
    Try to reset the range and see what happens
    Quote Originally Posted by BlueRob View Post
    As far as I am aware, you can't reset the range
    What you can do is check to see how it changes on each fill up of the tank
    I tend to fill up in units of 7 litres, this is about the minimum the trip computer can cope with, and also that is about the same as 1/8 on the fuel tank gauge
    I have noticed that when I fill up with 7 litres and the tank is low, the range sometimes does not respond
    Equally, on occasions the fuel gauge doesn't respond correctly
    The solution there is to switch off, let the fuel settle, then restart
    Otherwise, it sounds like the BC is not receiving from the fuel sender
  1. Range??
    Last Post: 31st July 2012, 12:54
  2. Just the range pls........
    By Whisky in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2011, 20:39
  3. Range!!!!
    By ianvilla1 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2009, 12:37
  4. Range
    By Atomic in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 18:20
  5. Range
    By Johnytuono in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2006, 22:06
