Thread: Car spanner light
    staffordshire
    Default Car spanner light
    Hi All,
    Just purchased our first vectra, it is a 56 plate v6 2.8t auto elite.
    When we turn on the ignition the spanner light apears on does not go out, however when we turn on the engine it disapears straight away, is this supposed to happen?
    Thnx in advance James
    I think it should on the facelifts. If in doubt, have a look in the manual
    Regular Member VECTRA_C_VIPSTYLE's Avatar
    CHESTER
    Think this is your service reminder light
    Hold down your trip pin then put your key's in keep pin pushed turn iggy on hold pin down for 30 seconds this should sort it
    hope this helps
    Regular Member 98vectra's Avatar
    stoke on trent
    Its recorded a fault,take it to the dealers and have the fault codes read wont cost you because its still under warrenty.
    Quote Originally Posted by 98vectra View Post
    I'm pretty sure there is a difference in the Facelift and Prefacelifts start up dash display. On the pre's it means a stored code, on the facelifts I think its supposed to show and go out. Check the manual
    Quote Originally Posted by VECTRA_C_VIPSTYLE View Post
    Nah, that's the oil can one with a spanner in it, and no longer used on the facelift - it's 'INSP' instead.
    Yep, that's exactly it. On the facelift it shows briefly when the ignition is turned on - it's only if it flashes when the ignition is on or remains on when the engine is started that there's something wrong. It's all in the manual.
    stoke on trent
    You might be right but if its true what silly D*** at Vauxhall decided to change that. Or have they moved the spanner light to its own display pilot lamp like the Astra,on mine it comes up on the display that shows when a door or boot is open.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
