Results 1 to 10 of 11
Thread: Eibach Springs
    West Mids
    Default Eibach Springs
    I suppose I should have really asked about this before I got the springs but Ive recently purchased some Eibach springs 10-65-007-01-22 now I know these are upto 1060kg which is what I thought my Vectra was (Elite 1.9 CDTi pre-face lift) but it turns out my Vectra is the 1080kg would it cause alot of proplems if I use these springs or would it be OK?. From the few threads I could find Ive read it maybe a little lower drop than 30mm on the front.
    Thanks alot
    Josh
    *Quick edit
    Im not sure if this is even posted in the right place so if its not would a mod be as kind to move it for me?
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Think you will notice it more when you have things in the back.....possibly grounding out. Can you not exchange them?
    West Mids
    I bought them off ebay the back weights are fine its just the front weight thats a little over.
    surrey
    Trim : SRI
    Year : 53
    YOu might get problems with rubbing etc on full lock over rough ground etc....
    West Mids
    Hmmm oh dear, at worst Il just have to resell them if they arnt any good
    surrey
    Trim : SRI
    Year : 53
    I think there are inserts you can get that actually go inside the coil ( if that makes any sense) which I believe makes them stiffer - that might sort out any issues you may have.
    I am sure someone on here with more tech knowledge will correct me
    West Mids
    Hehe I have no knowlege of this at all, I just had a quick glance then bid its only now that Ive had a proper look I noticed it was abit higher I wont be doing that again
    And thanks for the help so far!
    Here, there and every where!
    The springs on the back are all the same but as you now know the fronts are not the right ones for your car.
    You can fit them but it will sit lower, could bottom out and will invalidate your insurance.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by joules2.0t View Post
    i know you use to get them for the rears for when people where towing caravans so the back didn't drop so much
    surrey
    Trim : SRI
    Year : 53
    jOshuar
  1. Would these Eibach Springs fit?
    By coldo in forum Suspension, Wheels & Brakes
    Last Post: 25th August 2011, 18:31
  2. Eibach Springs????
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 20:03
  3. eibach springs
    By GSi-Col in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2011, 15:56
  4. Eibach springs
    By topline in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2006, 10:50
