Results 1 to 10 of 20
Thread: Do you have a rattle at around 2500rpm?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Default Do you have a rattle at around 2500rpm?
    If so then read on.
    Basically, i (HAD) a rattle at around 2500rpm and as the car was in the stealers getting it's first service i asked them to check it.
    I said rev the car to 2500rpm and you'll hear what i'm talking about.
    So, the car had the service and they rang me to say it was ready for collection.
    Anyway when i arrived at the garage, they charged me £170 for the service and when i enquired about the reported noise, they said no fault found Sir
    So i said, no there is a problem. The (Cough) mechanic told me he had driven the car over all sorts of bumps and roads, but could not hear the noise i reported.
    So i said WTF as i had asked them to sit in the car, rev it to 2500rpm and listen when i dropped the car off.
    The (Cough again) mechanic told me he had tried that too, but heard nothing. So i said follow me; sat in the car and revved it to 2500rpm and rattle, rattle, rattle and said to the mechanic, so whats that then? Mice?
    He agreed and they took it off to put on the ramp.
    He came back and said, yes it's a known issue that the flexi pipe from the exhaust manifold vibrates, so they (VX - i assume) have recommended putting a hose clip around it - which they have done.
    To end the story - if you have similar noises, it may be worth while trying this fix as it seems to have worked on mine.
    Picture added for info.
    Cheers,
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Perhaps suggest the moderators putting this on a sticky. I suppose it depends how many people have had the problem in the past.
    Jul 2006
    Mexico
    Well....I never go to 2500 revs.....the 3.2 drinks to much petrol :
    Good info mate...I'm shure many will benefit from this
    On another planet
    Engine : 2.0
    Nor do I BlueRob, but you mainly hear the rattling in 1st, 2nd, 3rd and 4th gear...If you know what i mean
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I had this rattle too, although at lower revs. Mega bucks to replace that piece of exhaust, luckily I managed to get it under warranty.
    If it happens again, I will be getting one of them straps.
    Birmingham
    How interesting, the stearlers saying to put a hose clip around it. What kind of a rattle do you get? My mate said that he had a weird noice from around that section, could this be it? Like a rocking sort of noise??!??!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Good find, I did this exact thing about a Month ago on my Cdti, I was quite chuffed when i found what it was as it was annoying the Hell Out of me...
    The braiding rattles against the flexible convoluted pipe underneath, Mine was doing it under load about 2500 Rpm, But was fine any other time ..
    Dean
    norn iron
    did you get them to check that oil leak out as well or have i had too many beers?
    On another planet
    Engine : 2.0
    Oil all over the engine bay as well mate! Apparantly they couldn't hit the hole I did comment on it and that was the explanation. I'll keep my eye on it
    On another planet
    Engine : 2.0
    Quote Originally Posted by DeanF View Post
    Dean
    Yep, that's the reason.
  1. CDTI jerking between 1500-2500rpm. Remedy ??
    By lesj in forum Engine & Drivetrain
    Last Post: 25th August 2012, 13:59
  2. Hesitation 2000-2500Rpm
    By Aidi in forum Engine & Drivetrain
    Last Post: 15th February 2012, 21:47
  3. limp mode above 2500rpm Vectra 2006 120bhp 1.9cdti
    By mani911gt3 in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 20:07
  4. CDTi 150 - Loss of Power upto 2500rpm?
    By Guapito in forum Engine & Drivetrain
    Last Post: 24th February 2011, 00:03
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
vectra flexible exhaust rattle
