Thread: Whirring noise when ignition switched off
    Regular Member old cruiser's Avatar
    slough
    Default Whirring noise when ignition switched off
    Yet another question for you all; after a run I've noticed this sort of whirring noise when I switch engine off noise diminishes to nothing within a few seconds, almost sounds like some sort of fan winding down if you know what I mean, it's not the air-con as this is switched off any ideas? don't suspect there's a fault, just me being inquisitive as usual!
    Cheers Pete
    Have you looked to see if its the engines cooling fans that could be on when you switch off? Pop the bonnet and get someone else to switch it off. Easiest way to eliminate that one.
    Germany
    Could it be the turbo shutting down ? I can hear that on my car, when the engine is switched off..
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Sounds similar to the cooling fan on mine. Does yours always happen? Mine only happens if the fan in running at the time!
    Regular Member david.aka.judas's Avatar
    Suffolk
    try and turn the interior fan off before you shut down, my fan had worn bearings making a weird sound, thankfully it was replaced under warranty.
    worth a try.
    It will be the ventilation servos. When you turn off the engine they close - the ones behind the dash. That's the noise you'll be hearing.
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    i heard the same noise and asked the same question
    slough
    Ah that makes sense mate cheers, I take it that happens whether the air-con or not is on?
    Also notice, the exhaust sounds a bit meaty if i pull away quickly with slightly higher revs than normal, exhaust i know isn't blowing already checked that, probably normal i suspect as the car is new to me , only had it since saturday and today is the second time driving it!!
    Cheers Pete
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    There is also another noise as well if your Anorak enough to listen.
    Sort of a Pshh & Thunk ...
    Intrigued ??
    Well it's the Over Boost Valve/Solenoid Opening to release the pressure on the Wastegate Actuator
    Im a mind of useless info
    Dean
    I get that
  1. Strange whirring motor noise
    By stuball in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 22:50
  2. Whirring noise persists!
    By ronnie63 in forum Engine & Drivetrain
    Last Post: 7th September 2012, 20:45
  3. whirring noise from power steering
    By Matt_Bankier in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2011, 21:48
  4. Whirring noise at 4,000rpm
    Last Post: 9th April 2011, 15:41
  5. whirring noise
    By matreya in forum Engine & Drivetrain
    Last Post: 19th March 2010, 14:50
