Results 1 to 2 of 2
Thread: vectra 2.0 dti ignition
    Apr 2008
    gateshead
    Question vectra 2.0 dti ignition
    hi all ive just had my veccy repaired last month cost 400 quid needed brakes done starter battery and solenoid it would not start hence phoning out a mobile mechanic got the car back the next day since then it still has really bad problems starting when u turn the key to start it it makes the noise it would make if u turn the key with the engine all ready running any help would be usefull the mobile mechanic said it was the ignition goosed could it be this any help greately appreciated
    Elgin
    Default ignition grinding on start.
    Hello, I had the same problem with my 1.9 cdti. My mate said the starter motor wasn`t engaging with the fly wheel properly. We removed the Starter, refitted it and made sure the bolts were tight. Good news is that it cured it, bad news is not for long it came back 6 weeks later. It only makes the noise if its been stood for a while and doesn`t do it if turn everything off then start it again! I Personally think that it`s just a case of replacing the starter motor but if anyone knows any better i`d appreciate it.
  1. Does the vectra 3.2 have ignition leads?
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2012, 11:30
  2. Vectra C (early 04) Ignition Key Problem
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 21:19
  3. 2007 Vectra Ignition Coil Help
    By heathersonline in forum Vectra C / Signum Troubleshooting
    Last Post: 13th January 2011, 09:09
  4. Vectra 3.2 05 Gsi clicking noise when ignition turned on/off
    By bignew in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2009, 19:36
  5. headunit on Vectra C independently of ignition ???
    By Buba in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2009, 20:41
vectra 2.0 dti battery
