Results 1 to 10 of 15
Thread: GSi handbrake - removing lever cover?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default GSi handbrake - removing lever cover?
    My handbrake lever has developed a knock/click when its applied. It sounds like its coming from under the handbrake lever cover and is akin to something catching / rubbing. I'd like to investigate further but how do you remove the cover?
    Haynes manual doesn't help - I thought this was a simple job.
    Jul 2006
    I'm sure someone posted recently that the handbrake was only ever supplied as an entire unit, so not sure if you could ever take it apart successfully.
    Yep, twas me. In terms of replacing anything, even the lever cover, the whole handbrake assembly is one part number.
    If you simply want to remove the lever cover to investigate anything, pop the chrome button off the end carefully (it's got little spring lug things holding it on) and then the cover will just slide off the shaft.
    East Midlands
    Quote Originally Posted by gtr1000 View Post
    Mine does exacly the same mate,when applied it sounds like it misses a notch or two with a clunking sound, i.ve had the handbrake mod done at the dealer,thinking that it may be better ,it is in fact slightly worse.
    It's a big job apparantly to remove the whole assembly,with the exhaust centre pipe needing to be removed hence not took mine any further.
    Jul 2006
    Mexico
    Mine does a big 'klank' noise when it applyed near the top.....there was a thread about this (I can not find it sorry) and if I recall right is the platic side surrounds of it.......if you pull it sofltly it will nor klunk and depends on the angle of it...if you pull it up and towards the center it will help to I think....simple issue you will have to learn to live with it IMO
    East Midlands
    Quote Originally Posted by macdad View Post
    Heres the thread concerning the hand brake clunk when applying,it may help.
    http://www.vectra-c.com/forum/showthread.php?t=2151
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Ah the Haynes Manual - Chocolate Teapot springs to mind
    Sorry can't be more constructive about the handbrake.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i had this and got the dealer's to change the damn thing.........then had the spring mod done.......then fitted my irmscher cover, it still does it sometime's and as rob said you can avoid it, not nice though as sound's propper c rap
    Midlands Mod Shop - NFFC.
    scotland
    so how do you release these lugs ???
    are they at the top , bottom or both sides of the shiny button ??????
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Quote Originally Posted by parapaul View Post
    It is and you cant
    In a nut shell to remove it complete you will need to drop the rear section of the exhaust to allow access to remove the exhaust heat shield, then remove the levers underside horseshoe locking pin, remove the rear section of the console, undo the levers 4 securing nuts, disconnect lever switch and lift away. Getting it back in is just as easy but getting the cable back on can be a ****
  1. handbrake lever
    By kamil_p in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2010, 21:14
  2. Irmscher handbrake lever
    By fasteddie364 in forum Styling
    Last Post: 2nd May 2010, 20:12
  3. handbrake lever
    By tankman in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2008, 21:27
  4. Handbrake Lever covers
    By rosssri in forum Styling
    Last Post: 27th March 2007, 15:38
  5. Handbrake lever
    By lborob17 in forum Engine & Drivetrain
    Last Post: 7th November 2005, 11:53
