Thread: Squeaking from cold
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Squeaking from cold
    I get a squeaking noise from the engine bay when I start the car from cold. It doesn't take long before it goes away.
    The cars a 1.9 CDTi (120).
    Any ideas on what this could be?
    The cars only got a month or so of warranty left would this be covered?
    Jul 2006
    cambelt?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Mouse????
    Northampton
    Engine : A20DTH
    Mileage : 88000
    When you park up at home the mouse enters the engine bay and goes to sleep. The squeaking you hear when u first start up is the mouse because it little feet are getting to hot. The squeaking goes away becuase the mouse has jumped off. Or it could be the Cambelt.
    I would suggest taking it along to the dealers the night before then going back in the morning and starting it up with one of the mechanics (use of this word in the widest possible way) next to it. Otherwise they will never find it!
    Jun 2006
    North West
    Oh poo... Any idea of cost??
    It just had a service a few weeks ago. Would have thought they'd have said something...
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Marky View Post
    You really are joking arnt you?
    I have had to always point out things to my dealers. If u report the issue under warranty if it goes wrong outside of the warranty you are covered. Best getting it checked to be on the safe side. Thinking of it could also be water pump or the alternator drive belt. Does it do it from very cold or everytime you start it up?
    Cambelt is not due for a change until 100k so it should be covered under warranty
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    It sounds like the Belt tensioner , thou i thought it was only common on the 150 engine, had the wifes Astra SRI done about 6 months ago, it was mainly from start up and went away, mind you after a few months it was there all the time.
    get it checked out, specially if its just been serviced.
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Yeh, sounds like auxiliary belt 'twittering'. Could be the belt, tensioner or pulley. If it is, best to get all 3 changed, I believe.
    Jun 2006
    North West
    Cheers for the responses.
    I popped my head into the enigine bay this morning and it seemed to be coming from around the alternator.
    It does seem to do it every time I start in the morning.
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Might be worth getting a modified alternator pulley. Next on my list.
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. Squeaking heater fan
    By waterbourne in forum Bodywork & Interior
    Last Post: 30th January 2012, 19:44
  3. squeaking noise when cold
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 29th November 2011, 15:47
  4. Fan motor squeaking
    By philc1210 in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 12:45
  5. Squeaking From Vent
    By tubby in forum Bodywork & Interior
    Last Post: 21st June 2009, 16:13
