Thread: Warranty
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Default Warranty
    As I have only till the end of November to go with my third year warranty on the motor, does any one know exactly what is covered.
    Every time I speak to the stealers, I get the same answer - no sir that not covered (gear knob fell off) and no sir that not covered either (Bushes and DAB radio losing stations).
    I get the impression thats its just the gearbox and engine?
    Jul 2006
    DAB radio should be covered
    Asking for new bushes after 3 years is a bit tenuous - they're a wear and tear item at the end of the day. I wouldn't expect to have them covered unless the mileage was VERY low.
    Gear Knob... Maybe? TBH you'd be better just superglueing it back in place
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    try another (nearby) dealer, you may get a better response, worth a phone call...
    Regular Member KeefyJ's Avatar
    May 2008
    Wolverhampton
    Prime question has to be - "WHICH warrantee?"
    IF manufacturers then up to end of Year three details are in the main documentation supplied with the car.
    IF Sureguard extension then applies to Year 4 and again details are in the booklet supplied by SureGuard.
    IF NET Q - seems to vary as to which one applied and this seems to vary by mileage and age; again - details SHOULD have been in the documentation supplied with the vehicle.
    Sorry to keep referring to the docs but that is why they are supposed to give you the full set withthe car...
    I can check current docs if that would help - can scan and post.
    Dec 2005
    West Lothian
    Quote Originally Posted by parapaul View Post
    Parapaul, the DAB radio is not covered is what they said. Loses stations every once in a while
    Bushes are not covered they say - only one year warranty on these .
    Gear Knob - now glued on.
    Warranty is the final third year from brand new.
    May 2008
    Wolverhampton
    Ta for feedback - in that case Radio loosing stations is a manufacturing failure and they should replace the unit with no question - unless it could be attributed to the drop in DAB signals with all the work supposedly being done withthe Digi TV/Radio change over - or of course your location.
    We had unit failure in 2000 Corsa & after reasonable push the dealer simply replaced the unit so there is precident.
  1. Do I get a warranty??
    By scotty84 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 13:00
  2. Warranty Direct or AA Warranty
    Last Post: 20th March 2010, 12:31
  3. Warranty
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 22:04
  4. warranty
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2009, 21:13
  5. Stealerships...warranty or no warranty, that is the question!
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 15:48
