Thread: 4 wheel alignment
    Nov 2005
    littleborough
    Default 4 wheel alignment
    Just had my Vectra 4 wheel aligned after lookers at Blackburn were supposed to sort.
    Pentagon at rochdale sorted and wheels were 8 deg out on the back and adjusted camber also.
    Vauxhall as a whole need to train their eng's properly to use technical machinery
    This was a problem from the early 02 52 reg.
    Anybody else had problems?
    Regular Member cpt slow's Avatar
    In a house
    ive had problems and still have , its a 52 plate . suspension feels damned awfull . any sugestions DAW had raer shocks and still bangs over bumps
    Regular Member 24vElite's Avatar
    Rustington, West Sussex
    Had the same on mine - 52 plate Elite. Dealer took it to local tyre place where they spent all afternoon resetting the front and rear suspension - drives like a different car now!!
    Nov 2005
    littleborough
    Default suspension
    Try an alignment but i dont think that should affect handling
    In a house
    did have a 4 wheel allignment done , took the guy 1 hour to do . Still bangs wallows.................... need I go on .
    Apr 2006
    SCUNTHORPE
    DAW, i have same problem can you please send garage details as dealers and tyre centres round here are teetering on muppetry,iam prepared to travel to have problem rectified pity the dealers cant do a proper job although they are not all bad.thanx m8 ian chalky white ,vactra newbie
    Apr 2006
    Suffolk
    Ive had the same problems when it comes to main dealers and tracking. They havent got a clue. I dont know if you all know but all vauxhalls have to be loaded with weights on the front of the car when doing the tracking. It has to be 70kg on each side with half a fuel tank. I would recommend a company called Elite direct in Rainham, Essex who manged to sort my veccy out and all its steering problems. My main dealer even had vauxhalls technical guy and said there was nothing wrong with the car. Elite soon put that opinion where the sun didnt shine!!
    Apr 2006
    SCUNTHORPE
    Wink 4whl alignement
    cheers m8 got car booked in on thurs re DAW THANX FOR HELP ALL THE SAME . Cheers chalky white
  1. 4 wheel alignment
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 21:42
  2. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  3. 4 Wheel Alignment
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 20:06
  4. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  5. Wheel Alignment?
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 23:09
