Results 1 to 10 of 11
Thread: Mixing oil grades
    Regular Member old cruiser's Avatar
    slough
    Default Mixing oil grades
    Been told that car has been serviced using 10/40 oil , is there any probs putting in 5W/30 oil when topping up?
    Cheers Pete
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Cant see why not, if your only topping up, ford even state that in their handbook.
    Might be worth a quick call to the local VX stealer to check though.
    i have to admit i have done it in the past without issue, but its only a top up not a litre though!
    goodluck
    Full Member Big Sig's Avatar
    Why did they use 10/40 anyway? It should be 5/30 unless your changing it every 8-10k
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    ^^I'd first get the right stuff put in there, if that is the wrong grade. Sharpish
    As for topping up with different grade, I definitely wouldn't do that personally. No sir.
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Vauxhall always put 10/40 in Mine for some reason
    But as long as you are putting Fully Synthetic in with Fully synthetic Etc then all will be fine, If you start mixing Mineral Oils Etc with fully synthetic, then you will have degraded the oils lubrication/Temperature quality's Etc
    Good Topic Here
    http://www.carbibles.com/engineoil_bible.html
    Dean
    slough
    Strangely enough I phoned 3 different dealers today and they all tell me it's 10W/40, so asked why as have heard it's supposed to be 5W/30 and the answer was, that Vectras from 2006 are recommened to have the 5W/30, so god knows who's right!!
    Cheers Pete
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Mate... i would stick to 5w/30 you cant go wrong!
    on flea bay its cheap enough... albeit my local VX want £12.75 per litre...
    So next service request...er no demand 5w/30. worth the investment.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    For those with CDTIs, then the experts on here (GSI3.2 and a few others) always recommend you use Vauxhall's own oil for that engine, and nothing else.
    That engine in particular needs very careful attention with oils (not saying the other ones in the range don't, but the CDTI is the most delicate some would say).
    Regular Member Small Racer's Avatar
    Jan 2008
    Hampshire
    What would be the better oil grade for 2.2 petrol direct??
    slough
    Have to say , one of the concerns I have is that using the thinner oil i.e the 5W30 ; may end up topping up a lot more frequent, but at the same time I guess it's more advantageous as far as lubrication goes for the timing chain / oil jet business and also tried running my old Omega 2001, 2.2 (Z22XE) I had on thinner oil and rattled a good 'un so went back to Vx Semi- synthetic and all was well.
    Cheers Pete
  1. Treated to a few up grades (pic heavy)
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2012, 19:02
  2. what suspension up grades ??
    By c9rum in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2009, 20:50
  3. Oil Grades
    By george in forum Engine & Drivetrain
    Last Post: 9th August 2007, 18:31
  4. Mixing oil?
    By grumpano in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2006, 16:13
