Results 1 to 10 of 13
Thread: Suspension clunk??
    Jan 2006
    Skynet HQ EMEC#5
    Default Suspension clunk??
    I've got a clunking noise coming from what sounds like driver's side front.
    Started to notice it yesterday on the way back from Billing, noticed it even more today on the way to work.
    It's doing it on straight roads when you go over slight bumps, & also if you brake a little bit harder.
    Can't see anything loose or broken, could this be the front anti-roll bar bushes letting me know they need changing?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sounds like the drop links ian m8
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by glynn View Post
    They've not been on that long
    the only other thing it could be is the bottom ball joint or the track rod end
    Jan 2006
    Skynet HQ EMEC#5
    Well good news, clunk sorted
    Brought the car into the workshop at break, jacked up drivers side & took wheel off to see what the problem was.
    Found this:
    It was sat between the spring & the shock, when the car went over a bump the spring would lift & the stone thought it could escape
    Then as spring compressed, it squeezed stone out of the way
    You can even see the mark it has left on the inside of the spring
    Jul 2006
    result! Little barsteward!
    I had something similar last summer - knocking suspension for ages which miraculously disappeared after a good session with the pressure washer in the wheel arch
    Now thats what i call a cheap fix ...........Can you imagine the stories VX would have told you if you took it to them for fixing !!!!!!!!!
    Full Member Big Sig's Avatar
    "oh yes, broken spring sir, we will have to replace the entire front end "
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    and rear end too.
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by Drinky View Post
    Oh yes I can imagine the stories Chris
    I thought if it was the anti-roll bushes, should'nt go that quick as they seemed ok going to Billing (even though I know they need changing).
  1. Big Clunk
    By Ben_ in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2011, 15:03
  2. i have a clunk
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2009, 22:03
  3. Suspension 'CLUNK'!
    By John3v36 in forum Suspension, Wheels & Brakes
    Last Post: 5th September 2008, 22:40
  4. Suspension Clunk Solution/s Recap
    By installer in forum Suspension, Wheels & Brakes
    Last Post: 22nd April 2008, 08:45
  5. Clunk!
    By B19CBB in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2008, 18:30
