Thread: Pre-facelift (GSi) xenon (self-levelling) dash warning
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default Pre-facelift (GSi) xenon (self-levelling) dash warning
    Looking for a bit of advice after this symbol appeared a few days ago. It came on occasionally a few months (but would stay off for ages) ago but is on know even if the lights are off.
    Not been out in the dark over the last few days but tonight I checked in semi-darkness and it looks like the passenger side has stopped self-levelling (difficult to tell as I donít think they reset and self-level all the time every time you switch on the ignition, if they were switched on before).
    Anyway, my question is Ė should I buy a second hand headlight or a new set of motors (I donít know if the motors can be bought/replaced separately).
    The headlight is perfect and my concern is that I buy a unit which could have aged motors and I end up back a square one.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Take it to vx and they will tell you whats wrong and what to do. have you had the fault code read?
    Jul 2006
    greenock
    Quote Originally Posted by Mugualigwian View Post
    Not had a chance to do anything with it - mark one eyeball against the wall looks like passenger side is not responding.
    Are the motors and integral part of the headlight?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Quote Originally Posted by Swatty View Post
    Just had a look in the owner's manual and it says Headlight range adjustment check page 130 so here you go
    • Light fault in system, the system is not ready for operation. If the curve lighting swivelling device fails the relevant dipped beam is switched off. The corresponding fog light is automatically switched on for reasons of saferty.
    • If control indicator illuminates for approx 4 seconds after the ignition is switched on, the headlights have been set to symmetrical dipped beam.
    Hope this helps
    Steve
    Also says you should take it to VX
    Jul 2006
    greenock
    [QUOTE=vectra 120;635455]Just had a look in the owner's manual and it says Headlight range adjustment check page 130 so here you go
    Thanks Steve, I will check that out .
    Has anyone ever worked on/replaced the self levelling lights ?????, or do I need to go to vaux (the independant garage can read the codes, but not sure if it is a vaux only repair - and a 2nd hand unit is not an option).
    I would imagine they are very similar to the standard lights, a motor in the lamp unit thats controlled from the level sensors rather than the manual control in mine. Are you sure your indi garage can read the codes for all the faults and not just engine codes?
    Just remember the most common fault is with the level sensors on the front and rear wishbones i have had two of these replaced on my Elite !!!!!!
    Jul 2006
    greenock
    I think they have contacts , they have found out the codes before.
    Jul 2006
    greenock
    Quote Originally Posted by Drinky View Post
    Great Drinky, some more really useful info, I never knew there were level sensors (tis starting to look like a visit to vaux )
    Many TAs for your help everyone
  1. Self levelling xenon fault
    By Spelly in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2012, 19:49
  2. Xenon self-levelling control unit
    By Swatty in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2011, 13:49
  3. Xenon auto levelling fault
    By pritch in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2010, 17:01
  4. Xenon Auto levelling issue (ongoing....)
    By RoddyKFC in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2009, 23:39
  5. Xenon Headlights Auto Levelling Issue
    By bigstevex in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2007, 21:14
vectra gsi xenon levelling
