Thread: Brake help needed
    edinburgh
    Default Brake help needed
    hI,
    Before I start I am new to this site, and use my 2007 Vectra 1.8 SRI as a taxi, yes a taxi lol.
    Just about to replace the rear discs and pads and have a small question. Does anyone no what size of rear discs I have on this model? Also..... do you need to disconect the brake pipe from the caliper to remove the disc? You did on my 2001 vectra b 2.2 sri.
    Would anyone no where I could get a passanger side rear wheel arch liner?
    Also..... Could anyone tell me how much a genuine set or rear pads would cost?
    Thanks all
    cambs
    hi
    not to sure but mine a pre-facelift but should be the same.
    i didn't need to disconnect brake pipe, but the calliper will need to be held
    somehow as not to let just hang thier.
    you will also need a brake rewind tool for the rear and some torx bits and a long handle bar to undo the the torx bolts as thier are very tight and thread locked
    as for the size just go to your local vauxhall dealer and ask them for the disc and pads (about £70 i think)
    try a local scrappy for the wheel arch cover or vauxhall again.
    hope this helps
    edinburgh
    Default brakes
    Should i be needing to change the rear pads at 8000 miles? Discs are scored as well.
    Its a 2007 sri not even a year old yet.
    cambs
    i changed my rear discs at 50,000
    the rear dont get much use and 8,000 seems abit to soon but you can always go down to vauxhall and get them to check them out for you.
    edinburgh
    Default brakes
    Had the car at vauxhall today, tech guy advised it will be a sticky caliper, however........he said if it was dirt or dust that caused the sticky caliper I would responsable?????????
    Dont understand that, the caliper is right next to the road of course its going to get dirty?
    Car goes in on wednesday, anyone give me some ammo incase they blame dirt?
    scotland
    unless you have the car in 2 foot of mud everyday then its their prob , the caliper is faulty thats why its sticking , dont be fobbed off wi them it is under warranty therefore its VX's prob !!!!
    - and you'll have 278mm discs on the rear. Vx do a disc/pad kit which costs £60 odd + VAT.
    As already said, definitely no need to disconnect the brake pipe and you'll need a brake rewind tool.
  1. brake light help needed
    By chrisg in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2011, 11:36
  2. Big brake upgrade - Info needed
    By Gavin2.6 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 21:38
  3. Brake Upgrade What's Needed
    By sunbeam250bhp in forum Handling & Braking
    Last Post: 27th March 2009, 23:22
  4. Upgrading rear brake caliper help needed
    By Baz07 in forum Suspension, Wheels & Brakes
    Last Post: 10th January 2009, 22:35
  5. urgebt rear brake pad help needed
    By tommoturbo in forum Suspension, Wheels & Brakes
    Last Post: 12th November 2008, 12:37
