Thread: 3.2 pad sizes.
    Regular Member jamesr's Avatar
    Lancashire
    Default 3.2 pad sizes.
    I have a 2003 3.2.
    What size are the pads on it?
    314mm? or 302mm?
    Full Member Big Sig's Avatar
    Could be either, I think some of the earlier 3.2's had the 302's. Unless that was just the elites??
    Lancashire
    I got 314 discs! all sorted now.
    Will I also need wear indicator leads?
    Its lists blue plug and black plug?
    Jul 2006
    Should just be one wear indicator lead on the N/S pad. Give your dealer a rting with your reg number and they'll be able to tell you which lead you need
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    does the wear indicator lead need changing when the brakes are done?
    Jul 2006
    If the warning light's come on then yes. If you're changing the pads early then you might get away with it. For less than a tenner, it's got to be worth doing regardless.
    And facelift cars don't have the wear sensor lead BTW
  1. tyre sizes
    By chris1804 in forum Handling & Braking
    Last Post: 19th January 2013, 13:22
  2. Tyre sizes
    By Biff600 in forum Suspension, Wheels & Brakes
    Last Post: 30th March 2010, 20:33
  3. tyre sizes
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 19:05
  4. Spring Sizes
    By rob1964bike in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2010, 12:57
  5. ARB sizes.....Again!!
    By JamesGTB in forum Handling & Braking
    Last Post: 9th December 2009, 09:46
