Thread: Evidence of oil
    Regular Member old cruiser's Avatar
    slough
    Default Evidence of oil
    Just taken the engine cover off and noticed , some residue of oil on the right side up near cylinder head (looking from front of car) have wiped off as much as possible, doesn't look like gasket is weeping as such but will keep an eye on it, just wondering if it's where they've fiiled up with oil on the serviceings and they've missed the oil filler hole as it were and it's spilled down the side or is it a common issue for leaks to appear around that area?
    Cheers Pete
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Usually quite tight mate, sounds more like a spill.
    Mileage : 000
    Clean it all off then look again in week or two. Most likely a spill.
    slough
    Cheers guys this what I'm thinking, well at least hoping!!
    Cheers Pete
    Was the oil that you removed clean and new, or old and dirty?
    A usual sign of an oil leak is when it is old and dirty, the same as the oil in the sump
    A usual sign of simply spilled oil is when it is clean and new looking, in most cases you can actually see the metal underneath right through it!
    Regular Member jonesy_ni's Avatar
    Co Antrim
    Had the same on mine, in same place, cleaned it off last week, must check it out again
    Regular Member shan's Avatar
    Was it just next to the oil filler next to the black pipe ? If it was it's the cheapo jubilee clips they use.
    Give it a clean and replace the jubilee clip for a real one.
    Sorry i don't know the pipe's name
    Vehicle : SRi
    Mileage : 137000
    You know its on a 2.2 petrol dont you guys?
  1. UFO's ..... More "evidence" ?
    By FIL 4822 in forum General Chat
    Last Post: 26th January 2013, 15:17
  2. Evidence - It didnt cross the line
    By spennny in forum Comedy & Humour
    Last Post: 28th June 2010, 09:53
  3. So, the 'Great Storm' any evidence yet?
    By AndrewTi in forum General Chat
    Last Post: 10th March 2008, 23:37
