Results 1 to 2 of 2
Thread: 2.2 Direct SRi with Management light on...
    Regular Member simp_2.2sri's Avatar
    Cheshire
    Smile 2.2 Direct SRi with Management light on...
    Hi all,
    My 2004 2.2 direct sri has started showing me its orange engine management light on the dash after starting. I borrewed a cheap code reader from a friend and its says fault code P1112 which relates to Intake Air Temperature sensor intermittant low voltage. I have cleared the code, but after about 3 or 4 start ups, it comes back again with the same code. The engine seems to run fine with the light on albiet I`m only getting 22mpg around town which is quite rubbish, it usually does at least 28mpg ish. My question is, does anyone know where the IAT sensor lives under the bonnet?? The only sensor I can see on the air pipes is the air flow meter, is it in there?? I hope not because it looks very expensive!
    Any help/suggestions/quick fixes would be greatly appreciated,
    Cheshire
    Anyone.........please
    By Shadrack in forum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. 2.2 Direct Recall - Engine Management Switch
    By rheumatoid in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 20:51
  5. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
