Thread: Strange noise on kickdown - turbo or Auto?
    Ripon, North Yorkshire
    Default Strange noise on kickdown - turbo or Auto?
    Hi everyone just joined as I have bought a Vectra 54 plate 3.0 V6 CDTi.
    Great car and no problem until I do a kick down (its an auto).
    About a second after a noise is emitted and lasts briefly (about half a second). The noise sounds like a metal to metal vibration sound as if a valve is being shut and bouncing at high speed. It is nowhere as high pitched as the turbo would be and my guess it would be equivalent to a few thou RPM type frequency.
    It is very repeatable and happens whenever the accelerator is suddenly moved and about a second later. If I were to move the accelerator suddenly to about 3/4 the sound would occur but much quiter. If suddenly moved to half then no sound at all. There is also a quiter echo. Not a real echo but the same sort of sound much quieter for about the same amount of time (half a second) just after the first sound has finished.
    I wonder if there is a valve connected to the turbo operation that is vibrating.
    I also wondered if this is not turbo related but auto transmission. It could be when the box changes down a gear under load. It is very difficult to tell if they happen together.
    I would be grateful for any help?
    Nigel
    Can some one help me?
    I can now update the symptoms as by first post was a little misleading.
    On flooring the peddle about half a second later there is a low pitched wistle in turbo terms but the sort of pitch you can wistle yourself. Sorry the best way I can describe.
    The wistle then goes and comes back in reducing volume waves. 3 or 4.
    Then on hitting 70mph the wistle is continuous.
    My thinking is that it could be a leak past a gasget under maximum boost.
    Does this ring a bell with anyone or am I barking up the wrong tree!
    The problem has been fixed. The sound was comming from a broken/loose steel gasget in the exhaust near to the turbo. It was an engine out job as the access is restricted.
    [Ex]Admin Duncan's Avatar
    Glad you got it sorted. I guess it had folks on here stumped with there being no replies!
    I'm guessing with it being an engine out job it was a fair few £££?, or did you have some sort of warranty on the car?
    Jul 2006
    Quite unusual not to get any help on here... Was it Road Trip season?
  1. Replies: 0
    Last Post: 25th June 2012, 13:36
  2. strange noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2012, 14:00
  3. Strange Noise From Turbo
    By Brooky18 in forum Engine & Drivetrain
    Last Post: 20th November 2009, 20:19
  4. strange turbo noise
    By twaiter in forum Engine & Drivetrain
    Last Post: 17th November 2009, 13:47
  5. strange noise when turbo is on boost
    By Dave Mac in forum Engine & Drivetrain
    Last Post: 13th July 2008, 14:28
