Thread: strange noise when turbo is on boost
    Nov 2007
    Chesterfield
    Default strange noise when turbo is on boost
    hiya guys , i have a 52 plate vectra 2.0 DTi , and when the turbo starts to boost i can hear a noise from under the bonnet on the offside wich sounds like a window is slightly down ( thats posssibly the best description i can give ) other than that the car runs fine. i had a look under the bonnet, couldent find anything untoward also the radio/cd player will only work off the controls on the steering wheel any ideas / solutions ? many thanks dave mac
    Full Member Big Sig's Avatar
    Has it always done this? It might be the turbo whistle you can hear, or possibly a split in one of the boost hoses. HTH
    Nov 2007
    Chesterfield
    hiya Big Sig, the noise i described started yesterday, in the past you can hear the turbo whistle as it comes on boost. this noise is different i will have a closer look at the hoses , many thanks for the reply . dave mac
    Regular Member addyboy1982's Avatar
    Northampton
    Regular Member Stu14t's Avatar
    Perth, Scotland
    I had an the same problem with another turbo diesel I had. What happened was the pipe from the turbo (boosted side don't know if it goes to the intercooler or on to the inlet manifold) was not connected back correctly and under no load there was no noise. However, when on boost there was a definite whistle, or even whoosh at times as the preasure forced it's way out.
    If it's a split hose could be difficult to trace as it only happens under load.
    Regular Member Karl's Avatar
    Sunderland
    my old DTi split the hose (kinda spider cracks) and it started doing the same, a new hose and it was all ok
    Nov 2007
    Chesterfield
    i took the black plastic cover off the top of the engine and found a split in the hose i have done a repair on said hose and all is well. ( will get a new hose tomorrow from the squealers ) thanks for the info guys . dave mac
    Here to help mate
  1. car running lumpy and now strange wooo sound when coming of boost??
    By richiem in forum Vectra C / Signum Troubleshooting
    Last Post: 4th June 2012, 13:00
  2. Strange power boost
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2012, 00:05
  3. Strange Noise From Turbo
    By Brooky18 in forum Engine & Drivetrain
    Last Post: 20th November 2009, 20:19
  4. strange turbo noise
    By twaiter in forum Engine & Drivetrain
    Last Post: 17th November 2009, 13:47
  5. Strange noise on kickdown - turbo or Auto?
    By NPS in forum Engine & Drivetrain
    Last Post: 14th August 2008, 12:51
