Results 1 to 10 of 13
Thread: Brake Fluid..
    East Midlands
    Default Brake Fluid..
    ??Does brake fluid have a shelf life so to speak,doing a fix on the wifes car(rear brake flexi hoses) mot failure,obviously need brake fluid for job and well noticed 500 ml bottle in shed which i'd completely forgotton about,only thing is i bought the stuff about 3 years ago...what i want to know is?can it still be used safely...any doubts and i'll gob it.Cheeers lads.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the AA recommend its changed every 2 years as i breaks down through heat and condonsation can also brake it down
    is it a brand new bottle and if so it should still be ok as you are only topping the fluid up
    Lutterworth, Leicestershire
    Brake fluid should have a proper sealed top (under the screw cap).
    If that seal is unbroken, it will be fine. If its broken, bin it.
    Brake fluid is HYGROSCOPIC, meaning it will attract (and absorb) moisture from the atmosphere. Water in the brake fluid will lower its boiling point, which can make it boil under hard usage. This causes vapour in the fluid, which is a Very Bad Thing...
    Mileage : 55000
    I don,t know of a shelf life. But it is Hydroscopic (it absorbs moisture) so the longer it is on the shelf the more moisture it would absorb. Me I would be more inclined to buy a new bottle ( asuming it would be newer fluid than the one you replaced) as your brakes are quite an important part of the car.
    PS abbytec. you were a bit quicker with your reply than me.
    But the sentiments are the same.
    East Midlands
    The plastic bottle is sealed and has never been used in which case moisture i would have thought can't get in there...i'm tempted to use it.
    Yep, agree with you Ed, except that you are under a common misconception that there is such a word as Hydroscopic, but there isn't... Try Googleing it. (Is Googleing a word???)!!!
    The word is (as I said) HyGROscopic
    Yeah, yeah, I know - Pedantic G1t
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would use it anyway.
    At the end of the day, the bottle is air tight, so how can air and therefore water vapour get into the fluid????
    Horses for courses, but I've never ever changed my brake fluid in any car I have ever owned, as a routine maintenace activity.
    Yes, I understand that brake fluid absorbs water, BUT, can someone explain to me (using simple language cos i'm only an automotive Engineer) how does the vapour get into the fluid at the business end (ie at the brake surfaces) ? ? As this is where it gets hot and bothered.
    Quote Originally Posted by Ste View Post
    Well I would GUESS, (note the word guess), that its because it is not a fully closed system - air MUST be able to get into the reservoir, or an air-lock would develop as the pads wore down, and fluid was drawn into the pressurised part of the system to "take up the slack" as it were.
    With the fluid being so agressively hygroscopic, I imagine that any moisture will permeate throughout the fluid, and therefore affect its properties.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I don't subscribe to changing brake fluid routinely as a maintenance activity. IMO it's just another way to extract cash from you and is unnecessary in 99% of cases.
    The question about air being drawn into the res and then the water miraculously being forced up the brake pipes by osmosis (or whatever action). The air volume being drawn in is low, and if the water content is a fraction of this, how much water actually gets into the brake system and then travels to the business end?? Probably not a measureable amount.
  1. brake fluid
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2012, 01:09
  2. Brake fluid
    By ed taylor in forum General Chat
    Last Post: 8th July 2012, 06:09
  3. Brake Fluid Q
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 11:29
  4. brake fluid
    By lizard in forum Handling & Braking
    Last Post: 2nd June 2009, 10:34
  5. Brake Fluid
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd August 2008, 12:27
