Results 1 to 10 of 18
Thread: bsr re-map
    staffordshire
    Default bsr re-map
    where is the nearist place i can get this done i live in sunny staffordshire thanking you john
    Northampton
    Engine : A20DTH
    Mileage : 88000
    At home by yourself because you buy it fom LMF
    Feb 2006
    Guttedsville
    It's a DIY job John. If you go to BSR's website, or LMF's, it'll explain.
    Basically, you order it, they send you the control unit which plugs into the OBD port under the ashtray, you download the map from an e-mail they send you, and you put it onto the car.
    And you can take it off if you need to, for servicing or warranty work etc.
    staffordshire
    what sort of increase of bhp and torque would i get cheers
    Regular Member mikey68's Avatar
    May 2008
    aberdeen
    I wouldn't worry too much about the figures as they mean little but you'll get a much improved drive. Power and torque will really impress you with a remap. You won't believe the same engines hides away under your bonnet. One of the good points about BSR is the ability to remap to standard whenever you want. Sweden on holiday right now so unless you have a slightly older car, you may need to wait for them to go back to work.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    This is what I!! was like when I got my stage 1.as Nike says JUST DO IT!!!!
    Feb 2006
    Guttedsville
    Quote Originally Posted by johnturbo View Post
    204 hp and 310nm torque.
    But that's 'only' stage 1, stage 3 is properly silly, 230 and 370 nm.
    Oh, and BSR tend to underestimate their gains....
    http://www.bsruk.co.uk/index.html
    Knock yerself out!!
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    As above.
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    I got 210 bhp - 238 ftlb torque.
    And a whole lotta pleasure. Worth every penny !
    See the east region R/R day results for a general view of BSR and 888 maps.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    I got 222bhp and 236 lb/ft from mine. Well pleased.
