Thread: Squealing brakes
    Regular Member Padster72's Avatar
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    Default Squealing brakes
    My front off side brakes make a squealing/squeaking noise when I am turning the wheel. Originally, was just when I turned left, but has started making the noise now I turn right. I would guess this means new pads (have to excuse me, I have no technical mechanical knowledge!).
    Any ideas?
    Haven't seen a warning light though. I have a 52 plate GSI, which I would have thought was fitted with the pad warning light.
    Jul 2006
    Mexico
    I dont think you need new pads....warning light should be on..on the other hand is not normal that they squeel while turning.....sorry cant help more but IMO new pads are not an option....my best guess is to check the CV joints...they do squeel while turning if they are about to die.
    Feb 2007
    Glasgow
    Check this thread...
    http://forum.vectra-c.com/showthread.php?t=47880
    Sounds like the same thing.
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    Absolutely f.......ng genius mate
    Had the car up on a jack, and had a quick look a few minutes ago, and yes, there it is, a small metal plate which was touching the inner disc. Bent it out a little, took the car for a quick spin, and noise has now gone.
  1. Squealing Brakes
    By richardg3.2 in forum Suspension, Wheels & Brakes
    Last Post: 6th February 2012, 16:17
  2. squealing brakes
    By dcm23251981 in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2012, 01:25
  3. Brakes squealing
    By davidlewis24 in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2011, 20:33
  4. Squealing brakes
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2009, 21:27
  5. squealing brakes
    By HooDLuM_X in forum Handling & Braking
    Last Post: 17th July 2008, 11:24
