Results 1 to 10 of 11
Thread: Battery Terminals
    Feb 2007
    GREENOCK
    confused Battery Terminals
    Polishing the car tonite and battery went flat after 1.5 hrs, had cd player on,,checked battery terminals and 1 had some time of acid flakes on it..it this correct or should i clean and put grese on it?
    Regular Member shan's Avatar
    It's just corrosion between the copper terminal and steel clamp. Nothing to worry about.
    Just give it a good clean with a wire brush and stick a good blob of Vaseline on it.
    Feb 2007
    GREENOCK
    thanks for that
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    just as shan said m8
    Feb 2007
    GREENOCK
    is that why the battery went flat?
    yes m8 all because of a cd
    Feb 2007
    GREENOCK
    is it because of ther terminals or just the cd been on to long...thought it would have lasted longer...cheers
    I'd think it was from just haveing the cd/radio on. Did you have a door open ? or just a window down.
    Feb 2007
    GREENOCK
    yes doors open at 1 point..thanks for that m8
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    might be worth getting the battery cked...........mine decided to give up the day b4 PVS only had to have the cd or radio on for 10 mins then car wouldn't start .plasma ran me off to get another one ....fitted it on at pvs camp ..and the ******s had only sold me a non charged one....but luckily Jay Kay was on hand with his boost starter..
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. cd30 wiring terminals.
    By jrh1 in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2009, 18:25
  4. Battery Terminals
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2008, 12:19
