Results 1 to 10 of 21
Thread: New mod - Hard wired FM stealth ipod CDC 40
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Default New mod - Hard wired FM stealth ipod CDC 40
    CDC 40 radio, no mp3, no aux-in. Having tried FM transmitters decided to have a go at a hard wired ipod option. I didn't want to go for the HK drive+play because I didn't want extra knobs and displays. Wanted to access the ipod through it's own screen/wheel.
    Parts were:
    The FM modulator (Clarion FM 863). This has 8 pre-set FM freqs and an on/off switch to isolate it when not in use to avoid interference when using the normal radio.
    Fakra adapters for the vauxhall aerial lead.
    RCA audio/ipod connector - also has a power input to charge the ipod.
    Started by modifying the cup holder. This is shown complete with lid but it comes apart. I needed to chop out the waisted portions (chop lines in white) to fit a classic (maybe not required for a nano) and a hole for the on/off switch.
    Power for the main box and the ipod is taken from the (switched live) cig lighter. Clarion box just sits freely below the cup holder on the 'transmission' tunnel.
    Finally, lined the newly widened cup holder with self-adhesive foam. Only been able to get blue so far but actually it doesn't look too bad. I do need to tidy up the corners slightly. The finished result.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Looking great bud, how much roughly for all the parts? Whats the sound quality like? Excellent work looks like a professional job.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    that looks very neat m8 and you can hide it away
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Good neat job, nice and stealthy!
    Jan 2008
    Lincs
    Year : 57
    Mileage : 100k+
    Sound quality is good. If I select the radio with the box turned off, there's a bit of hiss/noise until the box is on, then it goes silent - no interference at all. Turn the ipod on and it's very clear - maybe not as good as a cd but you'd have to be picky. Only downside I suppose is you just get a 107.9 showing on the radio display, but the ipod itself is easily visible for control.
    Total parts cost was £50. £25 for the main bit, £15 for the fakra adapter and £10 for the RCA/phono/ipod charger lead - all inc vat but plus postage, so more in reality.
    Regular Member sduk's Avatar
    Dundee, Scotland
    thats a great idea, is it easy to fit?
    Sunny Dartmoor
    Nice idea,top marks.......
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    That looks the nuts mate
    May 2007
    Somerset
    Default Aerial Adaptor question
    Hi
    i'm thinking of using the ideas here in connecting my car PC to my CD30 stereo. However I'm concerned about the aerial connections.
    I believe my stereo uses an aerial amplifier somewhere along the aerial lead (probably in the roof lining) so I also need to supply power up the aerial lead.
    The fakra adaptor shown in the pic doesn't seem to show a power connection however I have found a possible version here (http://www.caraudiodirect.co.uk/fakr...or-p-5632.html)
    Does anyone know if this is enough or will I need a corresponding DIN to Fakra lead as well? I can't seem to find a source for this cable though.
    Any help appreciated...
    Jan 2008
    Lincs
    Year : 57
    Mileage : 100k+
    Presumably all our aerial leads are similar. All that adapter does is connects the co-ax type lead plug to the fakra type plug on the radio. If the Clarion had fakra-shaped terminals, it wouldn't be needed. I assume all that an amplifier does is push out a stronger signal along the aerial lead? Not sure why you would need any additional power input. Not sure exactly what kit you are trying to connect however.
  1. Wired iPhone/iPod connection to CD70
    By MCD in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2011, 20:48
  2. Hard Wire my Ipod in
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2008, 10:53
  3. Stealth tax !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2007, 15:12
  4. Stealth Shelves
    By JCB in forum Electrical & ICE (including SatNav)
    Last Post: 7th July 2006, 19:54
  5. Stealth
    By MLC in forum General Chat
    Last Post: 18th February 2006, 11:43
