Results 1 to 10 of 18
Thread: BIG flat spot 3k rpm @ 60 3.0l auto
    Jun 2007
    Devon
    Default BIG flat spot 3k rpm @ 60 3.0l auto
    This car is driving me insane! 3.0L cdti 05 plate sri estate auto.
    Pulled out to overtake earlier, slight uphill, foot to the floor past the little 'click' in the peddle, banged up to 60 nicely, then just stopped, it felt like it was thinking about changing gear, then not, then again, then not.... almost almost like if it was a manual the clutch was slipping, but I don't think its that. I ****** hope not at 46k!!!!
    Then earlier going up my drive (pretty steep) it hit a flat spot about 15mph 2000rpm and just had 0 power at all, just took my foot off the peddle, put the power back on and it was fine....
    I really really really can't be arsed to take it back to Vaux as they are just a total pain in the arse here.
    Anyone got any ideas????
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    check the air intake,i used to have a flat spot changing 1st two 2nd opened the airbox full of 5hite leaves etc done the airbox mod,got a K&N air filter and give it a good clean out ,runs far smoother no flat spot between 1st and 2nd now worth a try ,hope this helps
    do you think it's engine or gearbox??.. just your gut feeling?..
    Jun 2007
    Devon
    my gut says clutch! I think it must be the engine, it shifts ok most of the time. It seems far far too dramatic to be the airbox.....
    there is no real 'clutch' in the auto... just brake bands for each gear...
    before you go much further, take it into an automatic transmisson specialist..
    Oct 2007
    Back in Belfast!!!!
    just reread your first post it does sound a bit dramatic for air-box just had a quick look and spotted flat spot
    take it back to vauxhall it there fookin job to sort it but sounds like it could be clutch related
    South east
    ATF related. That's my blind guess.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    ....could be gearbox........does it do it when you acelerate from standstill on a flatish road .....? do the engine revs drop ..or rise ..does the gearbox seem to react to the rev change ..? strange question this when the car is hot and has been driven and your pull up to a junction with you foot on the break does the car hunt and seem to want to move off ...
    no coolant cross contamination from trans fluid is there?...Thinking gearbox seals even thou it should have the upgraded parts fitted at that age..53 plates were the last of the worst...
    Feb 2006
    dudley
    different cooler our kid ...has a old type pipe cooler inbetween the rads...
  1. Flat spot :(
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2012, 19:06
  2. Flat spot
    By marc vectra sri in forum The 'Off Topic' room
    Last Post: 12th August 2012, 19:38
  3. possible flat spot?
    By andreitone in forum Vectra C / Signum Troubleshooting
    Last Post: 7th August 2009, 15:04
  4. Flat spot!
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 09:43
  5. Flat spot
    By mriley60 in forum Engine & Drivetrain
    Last Post: 3rd July 2007, 14:15
