Thread: Wet Wax??
    Regular Member Paulmac07's Avatar
    Jan 2006
    Livingston (W Lothian)
    Default Wet Wax??
    Hey,
    Can anyone recommend a good wax I can use without having to dry the car first?
    Cheers,
    Paul
    Jan 2006
    Wax it Wet from Turtle Wax. Ansolutely marvellous! I bought a bottle once with a cynical attitude towards it, didn't believe it would work, but it really does work!
    Spray it on all over the car when you've hosed it off, leave 30 seconds then dry the car as normal, and it's waxed! Easy as that...
    Jan 2006
    I had a bottle in my hand earlier tonight mate, but it was about £4 from ASDA, and I thought "nah, it'll never do". What a plonker...........
    Thanks JP7, I'll pick some up tomorrow.
    Regular Member blr123's Avatar
    Dundee, scotland
    When you hose the car down disconnect the hose from the pressure washer so that you have an open end then turn the tap 1 turn just enough to get a flow, the water will just drape over and if your car has been properly waxed the car will end up virtually dry anyways, then just apply Megs or Mothers etc Spray wax, the Megs one I know can be applied wet even in the rain......I've done it
    Bryan
    Jan 2006
    Quote Originally Posted by blr123
    Bryan
    Cheers Bryan, sounds like a good tip mate.
    Paul
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    wax it wet is really good stuff...very convenient for after a quick wash...
