Thread: DTi Engine history
    Regular Member greeningr's Avatar
    Jan 2006
    Oswestry
    Default DTi Engine history
    Just a questions that's been going around my head for a while now.
    I've noticed that the current range of deisel engines are 1.9CDTi or 3.0 V6 CDTi
    But in the past there was 2.0 DTI and 2.2 DTI
    Does anyone know why VX has gone back to the 1.9 unit, when other manufacturers are going from 1.9 to 2.0?
    Regular Member CBR600FV's Avatar
    Wales
    1.9 Unit is a current Fiat engine that meets the Euro4 emissions. Old style Vxl engines would have had to have a make-over to meet Euro4. Cheaper to go down the colaberation route. Look at Ford using PSA engines in Fiesta, Focus, Jag, Land Rover etc
    Regular Member OilBurner's Avatar
    Feb 2006
    Bromsgrove
    If you've experienced both then you'll understand my Vx went down the route of borrowing the Fiat engines. I had the Astra with the 2.0 DTI, whilst it was quick in gear, off the mark it was slow. It was pretty noisy once it'd run past 10K miles too, and the vibrations weren't great.
    I also test drove a Vectra Estate with the same 2.0 DTI unit, the extra sound deadening helped, but it still wasn't up to modern standards, and that's before you start considering Euro IV problems!
    IMO, the 1.9 16v CDTI is a far better engine than the old DTI ever was. The relative lack of noise and vibration at idle is remarkable. Better than the Volvo S60 D5 I drove recently, that's for sure.
    On the move, it's so refined it's perfect for cruising.
    IIRC, the DTI had slightly less turbo lag, but the new twin-turbo 1.9 should sort that out! Come on Vx, bring it on!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    CDTi is high pressure common rail (HPCR) injection, whilst the older DTi is a distributor pump type. Common rail allow far better control of injection events during combustion cycle, even allowing more than one fuel injection per stroke. eg Pilot injection (early in cycle), main injection and then a little post injection (late in combustion cycle) Some injectors allow 5 events per stroke. This would never be achievable with mechanical distributor pumps.
    The emissions, power density, fuel economy, noise, etc can be better controlled with HPCR. The ECM controls when, how much and how the fuel is injected - depending on engine operating conditions. This is why 'super chips' work really easily with these models, and can have huge increases of power / torque. And it is not a step backwards
    Feb 2006
    Bromsgrove
    Definitely not a step backwards, my old DTI used to smoke like a chimney stack under hard acceleration - not this CDTI baby! Vrrooom!
    Jan 2006
    Oswestry
    Thanks for the info
  1. an insight to my car history
    By small in forum Non Vectra C/Signum Album
    Last Post: 6th January 2013, 20:34
  2. My car history
    By y2joeyb in forum Quick Photo Album
    Last Post: 29th November 2012, 09:55
  3. Bit of history
    By paddyvectra in forum Comedy & Humour
    Last Post: 13th September 2011, 23:30
  4. Car History
    By onpiopah in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2009, 16:27
  5. History
    By nikroc in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 1st December 2007, 14:10
