Thread: Vectra-C show plates
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Default Vectra-C show plates
    Right i have just had the Vec C show plates delivered (Very quick service) the question i have they did not come with any fixings.
    So what would the best way to secure them?
    Regular Member Baz07's Avatar
    Lancashire
    Well if you don't have something like an irmscher plate holder i would use small squares of velcro to stick them over your plates when on the stand, but remember to remove them before leaving
    [Ex]Admin Duncan's Avatar
    I just use the sticky velcro Phil. Put one part of the velcro on the back of the show plates and the other part on your existing plates and then line up the velcro bits and voila!
    If your current plates are screwed on, you could, if you wanted, drill the show plates and fix them on instead of your standard plates, but obviously it'd mean drilling your showplates which I know I wouldn't want to.
    EDIT: Just saw Baz's post. That's what I used to use but they were never strong enough to hold it for a show without dropping off, so I then used longer strips of the same sort of stuff. Problem was it's a to then get off the plates on the car! This year I tried the self-adhesive velcro method and it sticks to the plates securely enough but peels off easily enough too.
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Thanks for that. Looks like a trip into town is needed
  1. Show Plates
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2008, 13:54
  2. show plates
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2008, 08:03
  3. Show plates
    By Spikey© in forum General Chat
    Last Post: 28th April 2006, 21:08
