Results 1 to 10 of 11
Thread: HELP???? Bro's Pug 106 wont start?
    Regular Member Craig1985's Avatar
    harwich essex
    Default HELP???? Bro's Pug 106 wont start?
    there is no spark at the spark plug or lead nor is there any fuel comming from the single point injector? any ideas? Immobilised? tried differnt coil pack? its a 1.1 petrol
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    fuel pump ?
    harwich essex
    as i turn ignition i hear a hum for few secs si i take it fuel pump is on? plus there is no spark?
    Sunny Dartmoor
    Sounds like immobilser to me...
    harwich essex
    what i thought. suppose its gotta be plugged in or summat for that?
    other thing i though was ecu?
    Apr 2008
    Staffordshire
    ok, the 1st problem you have is its french! (sorry)
    as you may have guessed im no mechanic, but it could be the CKP sensor ?
    http://www.aa1car.com/library/dis.htm
    Sunny Dartmoor
    Quote Originally Posted by vectra1.9cdti View Post
    I suspect so.........
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Try locking and unlocking car again. Might reset Immobiliser...
    Seen a same thing on a Clio.
    harwich essex
    it was the crank shaft sensor. didnt detect engine turning over so didnt add fuel or a spark cheers guys
    N Ireland
    check the fuel cut off hasnt been toggled somehow.... big red button near p/s shock tower. or crank sensor... also try a spare key and see if that works.
    a very comon problem in the phase 2 106 was the immobiliser's transponder aerial, this sits around the ignition lock barrel under the covers and slides off and on easily, 1 plug to it and its use is to pick the signal up from the chip inside the keyfob. they go gaga from time to time, normally leaving the car sitting for a while will let you start it again. basically if it doesnt pick up a signal it thinks your stealing the car.
    they are £15 ish new and can be fitted in seconds no pug tools needed and deffo no key coding etc so keep it away from dealerships, the like saying keys need programmed again etc at 45 quid a go.
    mmmm guess who worked for pug lol ... and i had a 106, ****** good car tho i thrashed the life out of it for 5 years and i really couldnt fault it at all. very little was std but the wee thing handled like a dream.
    EDIT - lol should have read the last post would have saved me 5 mins of typing a wasted reply lol
  1. car wont start.
    By gstore in forum Engine & Drivetrain
    Last Post: 3rd February 2013, 23:53
  2. Car wont start
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2012, 19:38
  3. wont start
    By wsophiecat in forum Engine & Drivetrain
    Last Post: 17th December 2011, 17:17
  4. Will not start then it will then it wont????
    By djconfused in forum Engine & Drivetrain
    Last Post: 29th July 2010, 21:37
  5. 2.0 dti wont start
    By dti111 in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2010, 02:12
