Thread: how to get from 2.2direct vectra to a vxr vectra?
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    Default how to get from 2.2direct vectra to a vxr vectra?
    howdy doody boys and gals was just looking at a couple of vxr's and the old noggin started twitching. how could i connect the heated recaro's to a non heated setup? how would i get the xenons to work correctly? how could i get the front and rear parking sensors to work off the button.
    not alot i know but i'm sure some clever tw4t will know.
    also would the brakes front and rear just be a straight swap as in the whole braking setup.
    Last edited by wanna veccy; 9th July 2008 at 21:20. Reason: brain twitching too much.
    Nov 2007
    telford,
    bumpaty bump bump bump bump heheheheheheheehehehhehehe
    member of the smoke patrol 230bhp+
    cambus interface will get the front and rear parking sensors working with no buttons "" works on speed for the front and gear for the back ""
    heated recaro' you may already have the loom in place
    xenons go for a standard xenons setup not active and your there bit of tech 2 and it should work fine or you could go for good hid setup and save a bomb
    Or it may be cheaper to simply buy a VXR - and a lot less hassle...
    Jul 2006
    And the brakes are a straight swap if you can find a set...
    Nov 2007
    telford,
    cheers chris, if i haven't got the loom for the heated seats would it be possible to install one? also matey 'cause i'm as thick as pig 5hit3 do you mean non afl xenons.
    did think that route penfold but when i sore what my insurance (i'm only just turned 22) would be along with tax and the rest of the running cost's it just seem's daft to shell out alot of money each year on a car that i'm not going to use to it's full potential. so it's just the look i'm after really.
    hope so paul they should be alot better than what is on at the mo.
    cheers fellas any body else know anything i would love to hear it pretty plz.
    cheers again you crazy bunch.
    martin.
  1. Opel Vectra 2.2direct 2005 - Finland
    By 16valve in forum Quick Photo Album
    Last Post: 17th July 2012, 22:23
  2. For Sale: 54reg Vectra SRi 2.2direct
    By jlock in forum Cars for sale
    Last Post: 12th April 2012, 13:06
  3. timing chain vectra c 2.2direct
    By vec22direct in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2011, 02:22
  4. Sudden power loss at 4500rpm, Vectra 2.2Direct
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 06:11
  5. Vectra 1.9CDTI 150 Auto v 2.2Direct Auto
    By mattr in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 19:16
